Idle problem CURE!!!!!!!! Finally!!
Old 06-07-2008, 01:17 PM
Angel's Avatar
Ok, I have been one of the thousands of victims of the horendous idle problem with my 07' Cobalt SS Supercharged. I do have many mods including the Stage 2 upgrade along with the K+N Typhoon Cold Air intake system and exhaust and many more. I noticed shortly after installing the Stage 2 kit that my cars idle was bouncing at idle and the problem got worse and worse to the point whereas I was stalling in traffic. I was forced to basically ride my clutch like nobodys business and it was just plain annoying. Pulling up to a red light and people looking at me thinking I was a young 16 year old wanting to show my ride up cause my rpm was consistentally bouncing from 400-1400. My fuel mileage has progressively gotten worse and it had started to become a safety issue considering I was almost t-boned as I rolled through a downhill stop sign trying to beat traffic but my car stalled again!!!
Anyhow, I am aware that there are many other balt owners out there who are experiencing the same problem as myself and I have seen what others were trying to do to fix this god aweful problem with no prevail. I have been working with the head GM tech in my city here for a while now to see if we could finally put this issue to rest. After months and months of monkeying around and ruling almost everything out except for a possible computer error in the car that wasnt tripping any codes which would be unlikely I thought to remove my throttle body to have a look. Just for the record all of you cobalt owners this is soo simply a blind monkey can remove the throttle body. Simply remove your intake and the throttle body is attached with 4-10mm bolts and 1-Vacuum line and 1-Electrical connector. Once removed I noticed that I had a bit of gunk in the body(not a significant amount and keep in mind my car have only 5k miles on it) but I figured I would give it a good cleaning with a $5 spray can of throttle body cleaner and then clean right around the valve(keep in mind when you open the valve be very gentle when cleaning to avoid any unwanted strain or possible damage). Once this minor operation was finished I reinstalled everything back to normal and fired it up and HOT DAMN!!!! Back to normal baby! Everything is running 100%. No more funky butterfly idle problems and my gas mileage is back to normal.
I cant believe I didnt figure this out long ago but s**t happens I guess. Anyhow, I know many of you are going to be wanting to jump all over this and fix your own problem but read this before you do. I dont like just fixing problems and saying "great its done" I want to know what caused this considering the car is so new with so few miles on it??? Im not 100% sure but I would assume it has alot to do with the filter being mounted so close to the ground and possibly some oil from the K+N filter and mabye some other debris happen to make its way up which would be strang but no impossible. My only possible solution to this rather than doing this cleaning every 5k miles would be for all of us to install oil catch tanks to allow some of this crud to remove itself from the intake and then every once in a while remove the vacuum line on your intake while the car is running and give the hole in the intake a quick spray of the throttle body cleaner.
Ohh and for you wanting to know why this problem was doing what it was doing is simply this - when there is any type of crud or oily compound around your intake valve and the valve may possibly stick a bit the vehicle recognized this and sees that it is sticking so it rushes to correct and overcorrects causing the valve to be opened to much and drops quickly causing the fluctuation from anywhere from a couple hundred rpm to 1500 rpm or so. I hope to god that this helps hundreds if not thousands of other owners out there who have been experiencing this problem because it drives us CRAZY!!! and I was near ready to go buy a gallon of gas and a match if a solution didnt come along right soon. Anyhow, please post replies once this is tried and let me know. I am very very curious as to how many people this is going to help.
G5ALIVE (03-13-2019)
Old 06-07-2008, 01:24 PM
craigk_c19's Avatar
bumb for those of yall that need to do this
Old 06-07-2008, 01:27 PM
Joeyavhu's Avatar
Hmm... This may be worth a shot when I stick the TB Spacer in there. Thanks.
Old 06-07-2008, 01:30 PM
Navarch's Avatar
Damn..... I'm gonna have to give this a try. This idle problem has been getting on my nerves for some time now. If this works, you deserve a medal for this thread!!!
Old 06-07-2008, 01:31 PM
craigk_c19's Avatar
hope it works for yall
Old 06-07-2008, 02:27 PM
Turbo06Sedan's Avatar
im going to have to look into this on my 2.4, but its quite odd..my rpm's flutter (300-600rpm difference) when cruising with cruise control on.
Old 06-07-2008, 03:17 PM
RedEcotecSS's Avatar
mine only does it when the A/C is on. think it'd be the same problem?
Old 06-07-2008, 05:52 PM
Angel's Avatar
Guys, if you are having an idle problem this would be the first thing to check. I almost promise that you will love the results and as far as anyone thinking that this is a tough job..Its not. If anything you should have this done within an hour. Good luck and keep me posted.
Have you picked up your TB spacer yet? If so then would you mind on telling me how to get one. Thanks.
Old 06-07-2008, 07:31 PM
eckow8's Avatar
Yep, at idle when my AC is on no matter if its on 1,2,3 or 4 my rpm's jump around from 600rpm- 1300rpm... its absolutely ridiculous so I don't even use my AC anymore. I'm def gonna check the TB but I think there is something else at play for when the AC is on...
oh and thanks for lettin everyone know
Old 06-07-2008, 07:40 PM
cblt12's Avatar
dude im going to autozone right now... this has been pissing me off so bad i almost want to hump your leg right now. it has been horrible lately and dies all the time! i love you.
Old 06-07-2008, 07:46 PM
JCswoosher2's Avatar
interesting
Old 06-07-2008, 08:29 PM
cblt12's Avatar
it worked!!!! im happier than a fly on ****!
Old 06-07-2008, 08:33 PM
plaxton's Avatar
sweet. i will try this on my next days off.
Old 06-07-2008, 09:02 PM
kenhebe's Avatar
I hate to admit that I didn't think of this being that I run a shop, but I have about 34000 miles on my car and when I took my throttle body off, it was as black as can be. Cleaned it out and the idle issue seems to be gone.
Old 06-07-2008, 09:13 PM
Dead Zen's Avatar
hmmmmmmm. oil buildup on the throttle body??? maybe we all need to bypass the pcv hose type thingy that goes into our intake
Old 06-07-2008, 09:22 PM
red06s/c's Avatar
Humm ill try this to...i thought it was a weather issue. When its cold ( live in ohio) its REALLY bad! Now its warm and it still does it but not as bad. i just has my s/c off yesterday and i did see some nasty in there, and i didnt even think bout cleaning it. I know shoot me!
Old 06-07-2008, 11:08 PM
Hockeyman's Avatar
would this prevent missfires at idle? My RPMs don't bounce but every 20 seconds my engine will misfire for about 10 seconds.
Old 06-08-2008, 01:30 AM
Angel's Avatar
Im almost 100% sure this will correct your problem. Seems you are having the similar problem as me. Good luck and let me know what happens.
Old 06-08-2008, 01:41 AM
djblass's Avatar
got the same problem but only when the a/c is on, going to take the car in this week i think its the clutch compressor
Old 06-08-2008, 04:12 AM
djblass's Avatar
this is a bit of what my car sounds like http://www.youtube.com/watch?v=EPZI3Xxjsts
Old 06-08-2008, 10:35 PM
AzulitoAlero's Avatar
yeh having the TB serviced is PART OF YOUR REGULAR CAR MAINTENANCE, GUYS!! You should do it whenever you change spark plugs, at the very least. I do mine every few oil changes. Clean or replace the air filter at the same time, it cant hurt... and a TB service at a shop will only run you 15-25 bucks. Its soooo easy though.. Easy to remove, then just hit it with some TB cleaner. voil-ah! =)
This reminds me though.. i need to do it soon on my newest car.
Old 06-08-2008, 10:41 PM
djblass's Avatar
well have you checked my video that doesn't sound like its the TB but i will clean it anywayz
Old 06-08-2008, 10:45 PM
Original Hayden Fanatic
REIGN SS's Avatar
Stay on topic, if you have nothing to contribute to the thread topic then don't post...
Old 06-08-2008, 10:49 PM
Coblt ss super's Avatar
oo i know wat im doing after work tomorrow, this is so bad, my car stalls everytime i go to a traffic light, not only that it idles so bad. my dad even noticed and asked wat i did to the car. my car i think is the worse with this issue and tomorrow imma clean it out and see if it works.
Old 06-09-2008, 01:11 AM
Angel's Avatar
I bet when your done you will be so happy you will run around doing the riverdance naked in your driveway!!!!
Quick Reply: Idle problem CURE!!!!!!!! Finally!!
