Japeatr's knocking at the track rebuild thread
Old 10-01-2016, 10:46 PM
  #376
South Central *********
JapEatr's Avatar
Cut 3/16" off the bevel of the an fittings, done deal
Old 10-02-2016, 10:46 AM
  #377
Omiotek's Avatar
This is on the electric pump?
Old 10-02-2016, 08:09 PM
  #378
JapEatr's Avatar
Yup, now just working the air out of the system
Old 10-02-2016, 08:10 PM
  #379
JapEatr's Avatar
Drove the car tonight, it's scary fast above 4k
Old 10-02-2016, 08:16 PM
  #380
63 Nova SS's Avatar
That's a good thing.
Old 10-03-2016, 11:31 AM
  #381
JapEatr's Avatar
heres the current punch list.
1. water leak at EWP fitting
2. speedometer unplugged presumably
3. oil leak at AN fittings at either turbo oil feed from galley, or drain line to block bedplate.
4. car is super lean under boost, need to add like 35% more fuel up top.
Old 10-03-2016, 01:59 PM
  #382
Hockeyman's Avatar
kick ass
Old 10-03-2016, 05:28 PM
  #383
Haven07's Avatar
Can't wait to see videos on this!
Old 10-04-2016, 01:46 PM
  #384
JapEatr's Avatar
ok
got the speedo working, and looks like teflon tape on the AN fitting for the water pump did the trick.
If my luck can hold out for my leaking oil fitting, I should be good to at least get a streetable tune worked up this weekend
Old 10-09-2016, 12:19 PM
  #385
JapEatr's Avatar
Well have a burst oil line, need to figure that out as well.
Been working on Hockeymans car to get it on the ground
Hockeyman (10-10-2016)
Old 11-21-2016, 07:18 PM
  #386
574
574's Avatar
Thread needs more video
Old 11-21-2016, 07:55 PM
  #387
63 Nova SS's Avatar
Also needs updated....
Was the oil line a turbo oil line?
Old 11-21-2016, 08:30 PM
  #388
mrbelvedere's Avatar
that's about all it could be
Old 11-21-2016, 09:02 PM
  #389
63 Nova SS's Avatar
Strange that Adrian also had the same issue at the same time. Different turbo though I'm thinking.
Old 11-29-2016, 02:22 PM
  #390
JapEatr's Avatar
ok well replaced the turbo oil feed line, now have to do the drain.
updates are slow. building 2 cars and its hunting season and the holidays.
Old 02-16-2017, 03:50 PM
  #391
JapEatr's Avatar
ok so having to replace the drain line again. additionally I found a coolant leak. im going to fix coolant leak and vacuum bleed cooling system next.
Old 02-20-2017, 04:09 PM
  #392
Hockeyman's Avatar
you got that bleeder from Amazon?
Old 08-02-2017, 11:55 AM
  #393
JapEatr's Avatar
both cars run and drive. still having cooling system PITA. next set is to relocate and replumb the EWP.
Both cars are monsters on the road
Old 03-08-2018, 12:29 PM
  #394
JapEatr's Avatar
just wanted to post an update. both cars are running, the ECTs read super low, and sitting idle too long with have them spike, i may replace the pump with a Davies down the road, but for now just wanting to get it tuned and driving.
Blake took his car home last weekend and has the dreaded fuel starvation from the canister that will require a surge tank.
Old 03-08-2018, 02:36 PM
  #395
63 Nova SS's Avatar
I wondered what became of the car. Figured you were like most and just faded away, then sold the car.
Old 03-08-2018, 03:00 PM
  #396
JapEatr's Avatar
nope still got it, just had a baby last month so its been low priority to say the least.
Old 03-08-2018, 09:30 PM
  #397
63 Nova SS's Avatar
Congrats, they sure change your life, and priorities. Raising a son was the most fulfilling thing I did with my life. Great honor to be called "daddy".
Old 03-09-2018, 11:53 AM
  #398
JapEatr's Avatar
yeah this is son #2
have a 6 yo and a 1 mo
Old 03-09-2018, 12:24 PM
  #399
63 Nova SS's Avatar
yeah this is son #2
Nice
Old 03-10-2018, 08:48 PM
  #400
JapEatr's Avatar
drove it today, making 32 psi strong and spinning thru all the gears! about to do some other rewiring of the fans direct to the controller as well as some other work
Quick Reply: Japeatr's knocking at the track rebuild thread
