Japeatr's knocking at the track rebuild thread
Old 12-04-2014, 12:32 PM
  #201
South Central *********
JapEatr's Avatar
not sure if i should tap and plug the PCV port in the head, kind of unsure how the Saaab LK9 intake has for a PCV. some input here will be helpful.
Old 12-04-2014, 12:33 PM
  #202
mrbelvedere's Avatar
i think its the same as lsj
Old 12-05-2014, 02:47 PM
  #203
armcclure's Avatar
Yep. Identical down to the valve.
Old 12-05-2014, 02:52 PM
  #204
JapEatr's Avatar
with the Powell PCV kit, should i replace the PCV valve in the new manifold and move or tap the head ?
Old 12-05-2014, 03:20 PM
  #205
armcclure's Avatar
We are working on that.
Old 12-05-2014, 03:22 PM
  #206
JapEatr's Avatar
details?
Old 12-05-2014, 07:24 PM
  #207
Powell Race Parts's Avatar
Vaughn the Saab has the same pcv valve and config etc as the LSJ. Arm and I want to do something different, we havent figured out the simplest and most efficient way to do it. At all times u have to deal with metered air for the PCV return. And you dont want to have to create expensive solutions with machining and welding, although it may come to that. U cant plug the head pcv port if you expect to be able to vent the blow by gasses effectively, so clearly we would like to seperate blow by gases from both ports. LSJ ports are two way on the rocker cover at any time, and only two way" off boost "at the IM, be it TC or SC. The issue with the IM is entirely off boost blow by, if the rocker cover external port is already running seperated.
The orifice sizing in the internal rocker cover castings and in the head and its PCV valve are selected to maintain vacuum even under boost, although that expectation has proven not be realised in both LSJ and LNF applications. Because there is power to be had through blow by gas management and maintainiing vaccum in the crank case, Alan is keen on a vacuum pump. He is currently running a Corvette air pump, we have tried the Kappa pump and its not up to the task ( 300 dollars in parts for that trial there) and there is a Pierpoint vacuum pump that drives off the intake cam on the LSJ style B207 SAAB variant, and that pump would be a really elegant packaging way to maintain good vacuum at high revs and power.
so thats the update. Many fittings/dead ends/lots of time spent/different ideas/callitdevelopment/sell it for 1.98 . lol
Old 12-06-2014, 11:40 AM
  #208
armcclure's Avatar
I am waiting on my hpt cable to be returned from repair to finish tuning and testing on a customer car, then we should be good to go.
Old 12-06-2014, 02:49 PM
  #209
I did not mention that revising the LSJ PCV to introduce fresh metered air down to the base of the crankcase is I believe a worthwhile addition to help reduce or eliminating sludge build up. LNF has that revision OEM.
Not an easy task. Requires one way valves, plumbing, revision to the rocker cover, plugging upper cylinder vents and of course, ARM testing it all
Old 12-06-2014, 04:01 PM
  #210
TStone's Avatar
aka a few decades until being released
Old 12-09-2014, 07:06 PM
  #211
Olybaltss's Avatar
Awesome info and updates regarding what you're currently working on. Thanks!
Old 12-10-2014, 09:17 AM
  #212
Viperoni's Avatar
So introduce fresh air into the bottom of the crankcase and have a vacuum pump on the top side... makes sense to me!
Old 12-22-2014, 03:16 PM
  #213
JapEatr's Avatar
just an update:
oil ports have been drilled for the mains
also the manifold/downpipe/dump tube/BOV are in possesion
my dump tube looks too big, as its flange is the same size as the manifold 38mm flange.
awaiting zzps response on these matters
i pulled Blakes head and about to drop his motor out as well.
the two heads are then going to be shipped to John for some solid fitment
Old 12-22-2014, 04:40 PM
  #214
andrewcarr1993's Avatar
When did you decide to switch to solid lash adjusters, thought you weren't going to get them. Interested to see how those will work out.
Old 12-22-2014, 04:48 PM
  #215
JapEatr's Avatar
Go a page or two back
Old 12-23-2014, 03:06 AM
  #216
Originally Posted by JapEatr
Well Bates made the decision for me, have neither time to wait, nor money for what they cost to have made at Bates.
Im running hydraulics after all...
I do APPRECIATE the passion from my friends that I trust - Walters, Powell, McClure. It is good to know they are discussing my engine as far as pros and cons.
I would have run them from the thinking outside the box and all out perspective, however im not going down that path in regard to the solids
I did and last post about them said it wasn't worth it for the cost.
Unless I just misunderstood and you aren't using solid lifters.
Old 12-23-2014, 09:09 AM
  #217
JapEatr's Avatar
Im running them on the exhaust side per some pro drag race advice
Old 12-23-2014, 11:18 AM
  #218
Rent me! per hour
Area47's Avatar
just an update:
i gave Blake head and about to drop his motor out as well.
yulp....
Old 12-23-2014, 11:35 AM
  #219
JapEatr's Avatar
Originally Posted by Area47
yulp....
i see what you did there hhaha
Old 01-05-2015, 02:43 PM
  #220
Hockeyman's Avatar
giggity
Old 03-12-2015, 01:24 PM
  #221
JapEatr's Avatar
Old 03-12-2015, 03:25 PM
  #222
574
574's Avatar
Love the sight of that... whats this I hear about an Ariel atom
Old 03-12-2015, 04:35 PM
  #223
Interesting! I was real close to trying to get a vacuum pump last year, back when we were trying out the gutted rocker cover with the line to the exhaust, which didnt work out at all.
Old 03-12-2015, 06:12 PM
  #224
JapEatr's Avatar
Its in the works, but have to handle some financial stuff this year
Old 05-26-2015, 03:27 PM
  #225
JapEatr's Avatar
thought it was about time for an update:
Shortblock is assembled. Gen 1 zzp girdled, Gen 1 LA Sleeve Moly Ductile
Snapshot of Hockeyman and mine cranks - each was lightened 1.2lbs
Quick Reply: Japeatr's knocking at the track rebuild thread
