Heat Exchanger Question - Help pease
I am getting a CA Heat exchanger and I was wondering if it is better to just replace the stock heat exchanger for the CA one, or just run both heat exchangers? Which do you feel would drop the IAT2 temps more? I was told that it may be better to run both becuase of the additional volume of coolant with both heat exchangers? I also am getting the GMPP dual Pass option B and wondered if 2 heat exchangers are needed when I plan on running the dual pass anyways?
I also plan on running approx 60% dexcool, 40 % water (distilled) and a bottle of water wetter.
I could use some advice?
anyone?
anyone?
Last edited by QuikSilverSS; 11-15-2007 at 03:44 PM. Reason: Automerged Doublepost
Here check out this Link & Yes you get more Cooling By having 2 H/E The Diagram on the 3rd page is how it sets up.
I'm running straight Distilled water & Redline Water wetter!
https://www.cobaltss.net/forums/show...t=76981&page=3
It does go below freezing here in canada, I think that running 60/40 dexcool/water should be alright, i am also going to be running water wetter with this mix. Is this better for IATs then just running straight dexcool? Or should I adjust the mix even more (ie. 50/50 d/w or 40/60 d/w) ??
IS it better to run 100% dexcool or run a combo of dexcool/water (i.e. 60/40, 50/50, 40/60 etc) for lower IAT2's with the dual pass option B and CA Heat exchanger????
Anyone?
Anyone?
Last edited by QuikSilverSS; 11-16-2007 at 09:11 AM. Reason: Automerged Doublepost
1 Post
Combo. As you know, water is the best property to cool a motor down safely. But water freezes, so what the dexcool/antifreeze does is raises the freezing point of the water and in return water raises the boiling temp of the dexcool/antifreeze.
The only time you run 100% water is when you live where it doesn't get under freezing.
Ok so what percentage of dexcool to water than for a climate that is freezing 4 months of the year? can I get away with 40% dexcool 60% water? Plus add redline water wetter??
No they are pre gapped, just put them right in, the best plugs in my opinion, I have used many sets of NGK BKR7E's at differnt gappes (0.040, 0.035, 0.032, etc..) and the ZEX are the best by far
No, the dexcool in the rad is also 50/50 mix from GM. If you go to Autozone or something, you'll see that they sell it both straight dexcool, or pre-mixed 50/50 for convenience...
Thanks guys, I think that I will just add distilled water and some water wetter than, when adding additional fluid for the dual pass and the CA Heat exchanger.
n20saturn
09-30-2015 12:26 AM
