K&N cold air intake - Cobalt SS Network
2.0L LSJ Performance Tech 205hp Supercharged SS tuner version. 200 lb-ft of torque
Technical Discussions ONLY!
LinkBack Thread Tools Search this Thread
Old 08-08-2007, 07:32 PM   #1
K&N cold air intake
i just got my K&N cold air intake today and it says its for the 05-06 and i got an 07 will this still work
07blackss is offline   Reply With Quote
Old 08-08-2007, 08:07 PM   #2
Pretty sure, try it. I don't own a balt, but I DOUBT GM would change the engine bay layout....99% it will
jflexe99 is offline   Reply With Quote
Old 08-08-2007, 08:09 PM   #3
Yes, I have one on mine. I just had to bend the lines coming out of the ABS unit down a little bit so that it wouldn't be rubbing all the time.
siracing is offline   Reply With Quote
Old 08-08-2007, 08:26 PM   #4
Images: 19
yea i have an 07 sssc and my k&n says 05-06 but it fits perfectly.
tkaugh29 is offline   Reply With Quote
Old 08-09-2007, 03:01 AM   #5
ok thanks alot
Old 08-09-2007, 11:08 AM   #6
Images: 3
how does everyone like their k&n?? just purchased mine from turbo tech today! curious to see how soon i get a cel. i had the intake mod up to this point which worked and sounded great but now want to complete the set-up with a real system.
chevyss is offline   Reply With Quote
Old 08-09-2007, 11:18 AM   #7
silversccoupe's Avatar
Images: 8
I really like mine.I've had it on awhile now and no CEL.I think you'll like the way it looks,lots better than that big hunk of black plastic.
silversccoupe is offline   Reply With Quote
Old 08-09-2007, 01:09 PM   #8
Images: 3
Quote:
are the intakes the way they appear as advertised? i thought the orginal early models were black, but now they have different colors to choose from...?? i was torn between choosing between the k&n and injen. i chose k&n b/c i feel a lot more confident with their support and quality, plus being the 'original' makers of a cai i wanted that classic mod as well. is a true cai louder than the airbox mod?
Old 08-10-2007, 02:59 AM   #9
Quote:
hell yea it is i got mine in and damm the supercharger is freaking loud
Old 08-10-2007, 11:53 AM   #10
Images: 8
The K&N Typhoon system is powdercoated silver,nice looking.
Loud??........UMMMmm Yes!
Old 08-10-2007, 01:09 PM   #11
Supporting Vendor
TurboTechRacing's Avatar
Images: 1
K&N always have and are Silver Metalic for the 2.0
Injen always have and are polished OR Gloss Black for the 2.0
TurboTechRacing is offline   Reply With Quote
Old 11-16-2007, 12:06 AM   #12
K&N or Injen, which is better?
danmon192003 is offline   Reply With Quote
Old 11-16-2007, 09:24 AM   #13
Supporting Vendor
Images: 1
Both are awesome intake kits. IMO comes down to color, polished or gloss black on Injen and Silver metalic on the K&N's
Old 11-16-2007, 09:32 AM   #14
lightningfast5's Avatar
Images: 15
I've had my K&N in for a little over a year now. I love it, I've never thrown a CEL. Don't listen to all those people that bash it cause its not a dry filter, saying that the oil is causeing there MAF(or whatever sensor they say it messes up) sensors to throw a CEL. I clean and re-oil my filter about once a month and never had a single problem. It does make the charger whine a lot louder.
lightningfast5 is offline   Reply With Quote
Old 11-16-2007, 09:34 AM   #15
Supporting Vendor
Images: 1
The increase is awesome in sound, a intake is a much on the SS/SC
Old 11-16-2007, 09:43 AM   #16
Images: 3
I have had a K&N for about a year now on my 2007 and there is only one problem I saw with the fit. the problem is that the metal that K&N uses is soft so where the CAI is you may get rubbing either on the abs lines or the ecu's heat sink because of the way i installed mine I did not want to mess with the abs lines so it rubed against the ecu to fix the problem I used a rubber and steel hoes clamp that you can buy at home depot for just that added protection. It will however rub the ecu heat sink on the corner but this is ok I have never had any trouble with this.
hightorque is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Two codes on 09 SS no_ss Problems/Service/Maintenance 11 10-19-2015 12:58 AM
M62 spacer plate- zzp goaliemo 2.0L LSJ Performance Tech 6 09-28-2015 02:37 PM
WTB many lsj bolt on parts. z28addiction Wanted - What to buy - All categories 0 09-28-2015 01:03 AM
CEL for Air/Fuel ratio DocSvensk 2.0L LNF Performance Tech 7 09-27-2015 03:24 PM
check engine light for improper air flow OrangeCoba Problems/Service/Maintenance 0 09-25-2015 07:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
