Le Riceburners OFFICIAL Build Thread
#2101
Yeah long as it aint oil pressure i think it will be something stupid. Theres a lot of wiring modification done in this car with gauges and grounds and **** being taken out reinstalled etcetera.
But yeah if it was taking a while to start up because it was needing oil pressure then thats a bad sign
#2103
It does but i think thats because i replaced my coolant tank and the new one didnt have the level meter thing in it. My fix was to rip the level deal out of the old one and tape it to the sensor plug so it doesnt set the code but doesnt seem to work.
#2121
So simple checklist:
Fuel pressure
Injector signal
Spark at plug
Coil signal
Functional Crank position sensor
Cam sensor isn't really relevant because the car WILL start with it unplugged, assuming no other issues.
Do you have all of those?
Fuel pressure
Injector signal
Spark at plug
Coil signal
#2122
Injector signal: no idea how to check, but considering all my plugs were soaked in fuel id say i have injector.
Speaking of that- is there any chance there is so much fuel in the engine that its contaminating the oil or that it will he harmful to start the engine?
Spark at plug: dont know how to check
Coil signal: think so because of spark plug tester
Crank sensor: check, brand new one and working harness
