Le Riceburners OFFICIAL Build Thread
The one to end them all.
Figured 'potential mini build list' thread was no longer just potential. So I fixed that ****.
Ok! As some of yall may know, I've been gathering parts for the last couple months to do a head + cams build and a valvetrain refresh.
For those who are unfamiliar with my car, here's last years featured car of the month that I won, because my car is the best ever :razz:
https://www.cobaltss.net/forums/feat...-fcotm-291116/
Minus this, that and the other thing, nothing has changed too drastically.
Heres my current list of parts under the hood/trans
Devilsown Progressive Meth Kit with 10 GPH Nozzle
Custom Fabricated Front Mount Meth Tank
2.8” Pulley, Multiple Pulley System
60# Siemons Injectors
ZZP 3" Intake
WOTBOX
ZZP Longtube Header/Catted Downpipe Combo
ZZP Resonated 2.5" catback
Ottp Stage 1 Heat exchanger
GM Stage 2 Belt
574's Dual Pass Endplate
ZZP Phelonic Manifold Spacer
NGK 1 Step Colder Spark Plugs
HPTuned JAMES RAKES TUNE OMG NOOOO
GMPP Clutch Upgrade Kit
ZZP Stage 1 Axles
TTR Engine Mount
Powell Race Parts Front Trans Mount
LNF Rear Trans Mount
LNF Shifter Linkage/Throwout Bearing
TWM Short Shifter W/ Base Bushings, & Cable Clamp
OK, so now here's the list of parts going on the car in the next couple of weeks
LSJION ported/polished/decked/cleaned LSJ head
ZZP Stage 2 Cams
Performance Autowerks 80# Valvesprings
ATI Super Damper (overdrive)
ZZP Neutral Balance Shafts
2.7” pulley
LSD Trans
80# injectors (for running the E85)
New meth kit with more failsafes
Machined front cover
New timing set
ARP Headbolts and timing chain guide bolts
ZZP Stealth heat exhanger
PC’d rims, cutoff shields and valve cover and strut brace
New retrofits
Luckily I’ve collected a good pile of piktarz for all to enjoy J
Extra set of wheels I powdercoated mustang blue
Said rims will be used with these 1” hub adapters for the hellafit
Also powdercoated these cut off shields…
for these!
new wiring harness and ballasts
Valve cover & new gasket
head
head gasket
front cover gasket
this badboy is from an 06 with 15,000 miles on it!
some fluid, clutch pipe and throw out bearing for the refresh. Trans seems to row through the gears for what the levers are worth. CAN ANYONE TELL ME what to check out as far as the input shaft play etc are concerned to make sure this thing is good to go?
timing stuff… all new guides, updated tensioner, cam gears, chain etc…
new S/C bolts, thermostat, a seal for something I forget… fuel injector isolators
the zzp neutral balance shafts. They are used but look great
ZZP 3" Intake
WOTBOX
GM Stage 2 Belt
ZZP Stage 1 Axles
TTR Engine Mount
ZZP Stage 2 Cams
2.7” pulley
LSD Trans
New timing set
New retrofits
for these!
head
head gasket
front cover gasket
machined front cover…
for the OD ATI superdamper!
here’s the performance autowerks 80# valvesprings
a zzp magnetic drain plug
new meth kit w/ goodies
ARP headstuds
ARP Timing chain guide bolts
Ecotec Viton valve seals
80# injectors and 2.7” OTTP pulley
ZZP Stealth Heat Exchanger… we plan to tap a hole into it so I can still run an option b
coppertech exhaust gasket and a v-band gasket that I never knew I needed for my longtube header I was wondering where the leak was coming from
I still am waiting for the cams to arrive. Then I’ll post a pic of those J
And finally some stikarz!!! Note that zzp and ottp failed to provide stikerz
crateenginedepot ftmfw
So the plan is this:
The car is in storage in my buddys garage. We have space there to work on our cars. We plan to lift the car up there to drop the cradle and go from there. Hoping to start next weekend, and be done a few weekends after that, and dyno tuning at Pwerks by march.
I still need new valves. Perhaps supertech valves. Otherwise… that’s about it!
Stay tuned and thanks for looking!
Big thanks to everyone that has helped me so far too!
ARP headstuds
zappitywow47 (11-13-2015)
