Mass Air Flow Sensor/meter
Old 03-05-2010, 04:09 PM
Beaucanada68's Avatar
Anyone have instructions on how to clean your Mass Air Flow Sensor once its out? I pulled it out of the Air Filter tube but the sensor is enclosed in a rectangular plastic housing with a metal plate on top. I havent seen a MAF sensor like this one. Usually they have a wire running accross it to clean. Should I just spray the hell out of it with MAF cleaner or is there something else Im supposed to do? Thanks for any help!
Old 03-07-2010, 01:30 AM
cobalt ss/sc's Avatar
buy a new one! if urs is bad
Old 03-07-2010, 01:01 PM
megaman311's Avatar
clean it, you will be fine.
Old 03-07-2010, 04:34 PM
ACESSbalt's Avatar
he was asking how
Old 03-07-2010, 05:44 PM
megaman311's Avatar
spray it really really well with this:
spray in the areas where air would flow, wait until it dries and reinstall.
Old 03-08-2010, 12:36 PM
ACESSbalt's Avatar
so i recently just got a motor put back in my car have everything hooked up or so i thought . i drove to the gas station and my lower radiator hose pops off(only thing i forgot was the clamp, i know im a *******) it gets all over the intake and MAF sensor.
on the way back the car went into limp mode and i havent been able to drive it since. everything is connected securely now. befor i found out they had MAF cleaner i used carb cleaner to clean it and put it back in. still goes into limp mode as soon as you hit the gas pedal. the car will idle perfectly.
the question is could this cause it to malfunction? will cleaning it with MAF cleaner change anything at this point? should i just buy a new MAF sensor?
thanks in advanced for any input
Old 03-08-2010, 12:40 PM
fredds-turbaltSS's Avatar
i think you need a new one, cleaning is one thing..but if your got drench in coolant i dont think cleaning will cut it...
Old 03-08-2010, 01:35 PM
Dainslaif's Avatar
Even if you hosed off your engine in coolant it shouldn't have gotten on your MAF unless you had it outside of your airpipe or something. >_>
Old 03-08-2010, 06:22 PM
ACESSbalt's Avatar
my **** was dripping with coolant
Old 03-08-2010, 11:27 PM
megaman311's Avatar
you will be fine after you clean it.
Old 03-23-2010, 05:42 AM
Pretty Crazy. Turns out my car kept throwing P0068 code for mass airflow. The Catalytic Converter was so clogged, it was choking the motor. Thank God there was a recall so I didn't have to pay for it. Only had 71k miles so beware if it happens to you. Car runs perfect now.
Old 09-30-2010, 06:46 PM
ericgt79's Avatar
hoping this will fix my tuning issue with my skewed afr's
01-12-2016 12:01 AM
no_ss
10-18-2015 11:58 PM
goaliemo
09-28-2015 01:37 PM
DocSvensk
09-27-2015 02:24 PM
OrangeCoba
09-25-2015 06:06 PM
Quick Reply: Mass Air Flow Sensor/meter
