Official TVS Thread!!!
Slobodan Milošević
the rod is longer, yes, but the rod ratio is much worse than the lsj. Just because the rod is longer doesn't mean that it rotates more freely. the rod length is only part of the equation.
I'm agreeing with you. Typically longer rod gets you to shorter crank length (faster rotating) or shorter piston (less weight to rotate). My gen 1 sbc 406 came with 5.56 rods and it now has 5.7's. wish I would have spent the money and thrown 6.0 in it. Shorter piston, less weight, easier to handle higher rpm.
I am in the process of selling the car and the guy who is interested wanted to know about getting it tuned without the meth injection. So far the car doesn't like any timing with the 2.8 and shitty 91 pump. Thinking of going up to a 2.9 or 3.0 to help it out a little.
no option for 93? I ran shell 93. What does he want to get rid of the meth for? I ran it on washerfluid and yellow bottles of heet. Can be found at any walmart and honestly i really only filled it less than maybe 5 times a year (2.5 gallon tank in trunk )
Slobodan Milošević
I noticed in those last couple of pictures that you both have some sort of return type fuel system with regulator? Did you add that or did your cars come that way? What are the advantages?
You both running E85? Where do you get fuel systems? Fairly straightforward conversion?
Sorry for all the questions just something I never considered and didn't know I might need.
Depends on your setup if you would benefit. Zzp has it as well as summit racing. That's where I got mine. But I don't just have the boost reference system. I also have the walbro 450 fuel pump and 160# injectors. And yes I'm on e85
