OPTION B - did i do this wrong? pics included
Old 03-11-2013, 01:29 PM
  #51
Administrator
Administrator
Staged07SS's Avatar
Originally Posted by bullet man360
Not trying to thread jack but while everyone is on the cooling subject, Does anyone know how easy it is to install a dual pass on a cx racing h/e? been thinking about the option b + dual pass but now you guys are talking about these problems/cores being flipped has me confused/nervous lol
Please see my how to for installing a dual pass. It is the same for any aftermarket heat exchanger.
https://www.cobaltss.net/forums/how-...rnator-274630/
Old 03-11-2013, 01:39 PM
  #52
Powell Race Parts's Avatar
Its not a difficult task but done right it takes time and care.
remove s/c and IM. swap the two lower cores end for end, taking care not to crush the soft ends of the cores and not leave behind the o rings and washers.
reinstall and carry on with option B. All explained in this thread and on the GM CED pdf document.
Old 03-11-2013, 01:41 PM
  #53
^p.s. that how to came in such handy when doing the dual pass dude
Old 03-11-2013, 01:45 PM
  #54
Administrator
Administrator
Staged07SS's Avatar
glad it helped.
Old 03-19-2013, 01:43 AM
  #55
Murdered SS's Avatar
Might be a stupid question but do you need dual pass to install option B?
Old 03-19-2013, 07:08 AM
  #56
Administrator
Administrator
Staged07SS's Avatar
No.
The car should have came with Opt. B from the factory.
Old 03-19-2013, 07:16 AM
  #57
Vander Nars's Avatar
No.
Naw someone felt it was a better idea to bleed the car for two months inside.
Old 03-19-2013, 07:19 AM
  #58
Administrator
Administrator
Staged07SS's Avatar
lol, true that.
Old 03-21-2013, 11:13 AM
  #59
haha.
well sorry guys i still haven't gotten back to working on this **** yet, its way too cold outside.
my iats are still 30 over iat1 all the time so its not terrible
Old 03-21-2013, 11:19 AM
  #60
Administrator
Administrator
Staged07SS's Avatar
haha.
That's about what mine ran at w/o my ottp gen 4 front mount HE.
I usually run around 15*F over IAT1 on avg. now.
Old 03-21-2013, 11:32 AM
  #61
that's what i was hoping to be at now
Old 03-23-2013, 04:26 PM
  #62
MrSlickSter06SS's Avatar
Yeah but i just wanted to ensure that its always as cold as possible. I see no harm in ensuring that the system has no air in it.
And beside last night (before the install) i raced five different cars almost in a row!
A 02 camaro twice, a g35, a 6.0 gto twice, a ws6 and a genesis. Only car that beat me good was the ws6; everyone else i either barely beat or was hangin on their rear bumper. Not a bad night
I agree dude, I did the same thing, always better to ensure especially if you have mods. I roated my line from the surge tank through bottom half of the framing.. kinda where yours is now just under neath it tho so its lower then the tank. And behind the head light housing.. I hope this helps you man gl!
Old 03-24-2013, 12:39 AM
  #63
Hey bro is there a diagram of option B install with no dual pass?
Old 03-24-2013, 08:13 AM
  #64
like this?
Old 03-24-2013, 02:10 PM
  #65
like this?
Ok so i tap the Y connector tot the orange hose coming from the Radiator cap?
Old 03-24-2013, 02:28 PM
  #66
yes. but i did see i posted a dual pass without option B. replace the t bottle reservoir with the Y top part heading over to the option B tank.
Old 03-24-2013, 03:29 PM
  #67
ok i see so then the air bleeder will be connected to the stock H\E correct. Sorry for thread jacking Riceburner really appreciate the help Powell.
Old 03-24-2013, 05:05 PM
  #68
what air bleeder? if you mean the hose for the option b then yes to the top of the stock h/e
Old 03-24-2013, 05:18 PM
  #69
^^^??? what air bleeder? lol the whole point of option B is the air bleed. just like the regular cooling system.
Old 03-24-2013, 06:19 PM
  #70
Also whats the best route for hose without it hitting the belt? over the top or under?
Old 03-24-2013, 07:13 PM
  #71
Size:  3.31 MB Y piece
then i use a chisel to open up the slot in the tie bar just to the left ( passenger side) of the air bag sensor, across from the dipstick. You can then feed the mainhose for the reservoir through there and it is protected by the tie bar from the supercharger.
the bleed line goes over the top of the rad tie bar on the cobalt they way i do it.
Old 03-24-2013, 09:55 PM
  #72
ok i see thank i just finished installing option B and IC pump. I route the breather hose threw the same way as the coolant hose. also on the IC pump the clip that goes into the IC pump for some reason didnt seem secure for me. has anyone else had this problem? Also thank you so much for your help very much appreciated.
Old 03-25-2013, 07:19 AM
  #73
Administrator
Administrator
Staged07SS's Avatar
Old 03-26-2013, 02:24 AM
  #74
ok i see thats the way i ran both hoses but I'm gonna change the air hose to over the top like the pic. I already see a change my temp run between 176 to 182 now before it was around 186 to 190. Also had to refill the surge tank already no leaks either i checked. Option B doing its job
Old 03-26-2013, 02:48 AM
  #75
thedude411's Avatar
What about running it through washer resovior filler neck spot?
thats what I did with mine
Quick Reply: OPTION B - did i do this wrong? pics included
