pics of plugging supercharger holes
hello my fellow coby's since the sticky
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/eaton-superchargers-modification-guide-95307/
i have been wanting to plug the sc ports now knowing that there are no myth's about iat2's rising and other bs, so heres what i used
make sure you clean the area with brake cleaner it will ensure that it sticks good
then turn rotors to were you can get your fingers in to make sure the quicksteel dosent go in the housing. and be sure to spin before it hardens (5min) and wipe excess off rotor blades ther should be minimal amount on blades...
here is the finished product
i find alot of people dont hear a big diff if there running "the ghetto ass air box mod" i have a cai... it is much louder and im running my stage 2 pulley right now cause of summer temps ill drop the 2.8 on and make a vid tonight i promised some other people in another thread i would
only prob is i dont have a video of before
Last edited by hungryhip-ccp; 03-23-2008 at 11:50 PM. Reason: Automerged Doublepost
x10
i have a feeling those holes were put there for a reason. I doubt they would take the time to drill 2 holes in a supercharger, if they were pointless. I would not recomend doing this, unless you don't care about your warrenty, or you want to take the rise of blowing your SC.
plus if ur worried about the IAT's then port the damn thing,they dont port the silencer holes so whats their use? to make the SC quieter..
Ralliartist go to the top of the 2.0 section and read the SC Modification guide. Has quotes direct from Eaton.
Im pretty sure GM didnt make our blowers
direct quote frm the sticky Ralli:
Air Leakage Ports:
The two oval slots on the output plate are air leakage ports. Their only purpose is to decrease operational noise from the blower. Arnie, from Eaton Corp., explains their function like this, "When you stomp on the gas, the boost shoots up and the air flow goes supersonic. The air then slams back into the output plate and through the leakage slots, which reduces the hammering of the air into the housing causing less noise. The OEM can not have such loud NVH, thats why we put them in the housing. The 2 small ports are not there to feed air, only to reduce noise." Basically, for the best flow and most efficiency, these ports can be blocked off, making the outlet port (triangle slot) the only port on the outlet plate of the housing. Closing these ports will not increase IAT's; however, it will make the supercharger much louder when in boost. As an example, aftermarket supercharger companies, such as Harrop, Roush and Magnuson do not use these slots in their blowers. It should be re-stated, that you should consult professionals regarding closing these ports; and do not, for any reason, plug them with JB Weld. Improper closure could eventually lead to pieces coming apart and loose debris destroying the rotors and housing. Opening up these ports will only have a negative effect on efficiency. Do not port them.
heres the thread...
https://www.cobaltss.net/forums/show...silencer+holes
now please take a
Enjoy!
Air Leakage Ports:
heres the thread...
now please take a
Enjoy!
its what i'm here for
idk lol
idk lol
oh well- i dunno if i would try this... too risky
video is in the making
well some might say theres is just as loud REMEMBER this is on a 3" pulley i WILL make video's tomorow of 2.8 and less beating on my stock clutch lol but 12k and 260hp+ to the tire and she's still going strong...
in the car
http://s247.photobucket.com/albums/g...t=100_3633.flv
out side
http://s247.photobucket.com/albums/g...t=100_3634.flv
watching the video i do belive on the first one i hit rev limiter due to tire spin and shifted a little early, the clutch tried to do its job releasing a chirp from the tires but then the tires caught and the clutch slipped...
second time i tried to time the 2nd gear to end right after the camera but still didnt make it and had to contemplate on shifting or not so i missed third lol i guess im more of a performer when im under pressure cause ive never missed third while doing no lift shifting during street racing... he he street racing its so much funner than the track... imo
Last edited by hungryhip-ccp; 03-24-2008 at 03:07 AM. Reason: Automerged Doublepost
