The quest for 600whp
Old 11-20-2013, 05:50 PM
mrbelvedere's Avatar
Originally Posted by nhanson
What about inline pump and surge tank?
Put surge tank between inline and in tank pumps.
a surge system uses 2 pumps one to fill one to feed but empty is empty
Old 11-20-2013, 05:54 PM
BlkWdoSS's Avatar
If you want 600 with a big turbo you better get creative.
As far as injectors, you need to calculate your BSFC and measure that at IDC of 80%
For example, if your BSFC says you need 320lb/hr, you would take 320 divide by 80 (for your %) then multiply by 100. So you would need 400lb/hr, now divide that by 4 (number of cylinders) and you get that you need 100 lb/hr injectors.
Similar math for your fuel pump, if you do the math at 75-80% then you have a good ceiling for expansion. Just get all of your conversions right , things are measured differently by each manufacturer i.e. lb/hr, gph, lph, cc/min etc.
If you want to have a discussion about how to get that turbo spooling faster and other tricks, PM me and Ill fill you in on everything I have done as I have tried pretty much everything and have had some success and some failures.
I cut my spool down from 6000rpm to under 4000rpm on the BW S366XL
Old 11-20-2013, 09:26 PM
574
574's Avatar
PMing^^ good guy to know
Anyone know anything about zzp's stage three turbo cams? They have specs for stage two and I know a few people with them but I have heard nothing about the stage threes. I wonder if they would be hard to DD on?
Old 11-20-2013, 09:34 PM
kdub1492's Avatar
So you ever gonna come out this way with that turd and cruise with me?
Old 11-20-2013, 10:05 PM
call comp and go custom
Old 11-20-2013, 10:08 PM
TStone's Avatar
This times a couple more times
Old 11-21-2013, 11:08 AM
574
574's Avatar
Cams from comp are probably a lot more $$ right?
Old 11-21-2013, 12:02 PM
nope they are not
Old 11-21-2013, 12:46 PM
TStone's Avatar
Total comes out to be a little less than new ones from zzp
Old 11-21-2013, 12:52 PM
574
574's Avatar
Awesome. Any brand recommendations for egt gauge?
and do I need ATI overdrive or underdrive?
Old 11-21-2013, 02:09 PM
  #36
TStone's Avatar
It says on zzp. I believe it's UD
Old 11-21-2013, 02:15 PM
  #37
574
574's Avatar
"U.D. is recommended for turbo applications. It will help keep your alternator alive and allow for high rpm engine reliabilty."
Doh
Old 11-21-2013, 02:25 PM
  #38
nhanson's Avatar
In for 595whp
Old 11-21-2013, 02:34 PM
  #39
InfraRedline's Avatar
I have a Defi egt gauge that I like. They are like $240 for that one. And yes, straight from Comp is cheaper.
Old 11-21-2013, 02:49 PM
  #40
you will need adj cam gears and learn how to check the cams and alan can put the hex in for you
Old 11-21-2013, 08:13 PM
  #41
BlkWdoSS's Avatar
I use an AEM one, but as long as it is accurate is what matters
Or send them to Mr. B and make him do it lol
Old 11-21-2013, 09:18 PM
  #42
574
574's Avatar
So now I'm thinking:
ATI
Johns bolts
Valve springs
Reverse split cams
And see how far the BRFPS will take me fuel wise . With all that I probably won't be able to swing anything else fuel wise like pump(s).
Old 11-21-2013, 09:25 PM
  #43
get it done
Old 11-23-2013, 03:36 PM
  #44
574
574's Avatar
Glowshift egt gauge and treadstone turbo blanket ordered! Second thought, I have a tripple pod and a dual on the gauge cluster. Where should I put this single gauge? I'm thinking of making a mount for behind the steering wheel kinda between the two other gauges. Any suggestions?
Old 11-23-2013, 03:50 PM
  #45
TStone's Avatar
jesus ****.. what 5 do you currently have?
Old 11-23-2013, 03:55 PM
  #46
V8THIS's Avatar
You shuld buy my ttr intake manifold, use that wit a 75mm throttle body and that will help you get to 600
Old 11-23-2013, 03:57 PM
  #47
hey **** face go post your piece of **** manifold up in the ******* for sale section you don't need to spam peoples threads for your junk
  #48
574
574's Avatar
Boost wideband Interceptor oil pressure volts. I thought about getting one of those cup holder gauge pods but I use my cup holders!
Old 11-23-2013, 03:58 PM
  #49
V8THIS's Avatar
Originally Posted by tstone
jesus ****.. What 5 do you currently have?
what are you talking about?
Old 11-23-2013, 03:59 PM
  #50
V8THIS's Avatar
it is posted, big tough guy!
Quick Reply: The quest for 600whp
