The quest for 600whp
Old 11-23-2013, 03:59 PM
  #51
574
574's Avatar
Originally Posted by V8THIS
You shuld buy my ttr intake manifold, use that wit a 75mm throttle body and that will help you get to 600
That manifold looks almost identical to the one I have, and I don't think that tb will work.. looks like cable.
  #52
mrbelvedere's Avatar
Originally Posted by 574
Boost wideband Interceptor oil pressure volts. I thought about getting one of those cup holder gauge pods but I use my cup holders!
you don't need a volt meter gauge oil is nice to have
Old 11-23-2013, 04:01 PM
  #53
it is posted, big tough guy!
good then quit spamming people threads with your garbage
Old 11-23-2013, 04:03 PM
  #54
V8THIS's Avatar
that manifold looks almost identical to the one i have, and i don't think that tb will work.. Looks like cable.
the one i have on it now is cable yes, but the fly by wire gm truck tb is the same mounting flange, i didnt see you had a manifold in the pictures in your garage,
a big part of making power that big is getting the air in, i reccomend going bigger on your tb harmonics and valvetrain are very important too dont get me wrong.
Old 11-23-2013, 04:09 PM
  #55
TStone's Avatar
ew ditch the volts
Old 11-23-2013, 05:00 PM
  #56
V8THIS's Avatar
ive got some rc 1200cc injectors if those would work for you too
Old 11-23-2013, 05:04 PM
  #57
BlkWdoSS's Avatar
Please stop, the OP didnt ever ask about purchasing ppls parts, he wanted a discussion about building fuel systems to handle 600whp on a turbo LSJ. If you want to sell parts, keep it in the classifieds section.
Old 11-23-2013, 05:09 PM
  #58
574
574's Avatar
I am in the market for ATI turbo cams brfps and that's about it as of now
Old 11-23-2013, 05:15 PM
  #59
BlkWdoSS's Avatar
I can build you a cost effective return style if you want, are you keeping evap or deleting?
Old 11-23-2013, 06:07 PM
  #60
conerboner's Avatar
sub'd for more knowledge. I will be putting my s256 on my lsj this winter and there is some helpful info in here.
Old 11-23-2013, 06:10 PM
  #61
574
574's Avatar
That would be awesome. I was gonna hope zzp put them on sale for black friday. I know they can be pieced together for cheaper, I just don't know what I need. I am planning on deleting evap
Old 11-23-2013, 11:57 PM
  #62
574
574's Avatar
No need now, just bought a BRFPS and turbo ATI from Lars Holy **** I spent some money today
Old 11-24-2013, 12:25 AM
  #63
taintedred07's Avatar
You and me both lol
Old 11-24-2013, 10:00 AM
  #64
BlkWdoSS's Avatar
That was fast! lol
yea if you delete evap then you only need about 4 ft of hose, a regulator and a handful of fittings SCcobaltSS and I built each of ours for around $150, his dad was able to machine the fuel rail end fitting for his which saved even more money.
Old 11-24-2013, 10:25 AM
  #65
574
574's Avatar
That was fast! lol
So your regulator is on the end of the fuel rail? Whats everyones thoughts of running a -8an size fuel line?
Old 11-24-2013, 12:57 PM
  #66
BlkWdoSS's Avatar
yep attached directly to the end of the rail, but that is where I wanted, I couldve easily mounted it to the firewall and ran a line from the rail fitting to it.
Just gotta figure out the math on it, Gotta remember that by increasing the line size, you may increase volume but you decrease pressure. and you have to have the proper size return line as if it is too small then you wont feed back quickly enough thatll keep the regulator from doing its job and may cause crazy high pressure.
Old 11-24-2013, 03:09 PM
  #67
a 6an would should be plenty(stock may suffice shoud try and see) then run an 8an retuen
Old 11-24-2013, 04:27 PM
  #68
574
574's Avatar
Yeah I heard you can use the evap line as the return line so I'll probably do that. As for the increased fuel line size, it was just an idea jolly brought up to me.. may be a good idea in the future but for now stock size will do.
Old 11-24-2013, 05:21 PM
  #69
South Central *********
JapEatr's Avatar
6AN is more than enough line
Old 11-24-2013, 06:16 PM
  #70
armcclure's Avatar
2.5" compressor outlet to a 4" tb...
Seems legit
:facepalm:
As far as fuel line... Look at the size of the injector nozzles. The actual outlet. Imagine that x4. Compare to a -6.
Oh yeah. It's plenty.
Old 11-24-2013, 06:22 PM
  #71
What's the purpose of deleting the evap system?
Old 11-24-2013, 06:27 PM
  #72
TStone's Avatar
Less ****. More room for activities.
Old 11-24-2013, 07:16 PM
  #73
574
574's Avatar
Pretty much, and it looks purty
Old 11-24-2013, 07:30 PM
  #74
armcclure's Avatar
Once you're applying boost to the tb it's best to relive it anyway.
Old 11-24-2013, 07:36 PM
  #75
574
574's Avatar
I still haven't decided what cams I wanna go with. Custom from comp seems like a pain because I don't know what specs to tell them, and I don't know how to use adjustable cam gears.
As for zzp cams, I don't know if I would want stage 2 or 3 reverse split. I want the car to still be DD friendly.. hmmm
Quick Reply: The quest for 600whp
