View Poll Results: 2.0 LSJ ONLY: What intake do you have?
Voters: 1084. You may not vote on this poll
SS/SC intakes
#253
i just installed my k&n cai and it seem a bit to long. the filter pushes on the bottom part of the valance. is this normal? or didn't i do something right? any suggestions?
#255
I just installed my cold air intake tonight and 20 miles later my check engine light came on...i knew this has been some problems with others.....any suggestions on what to do??
#256
I installed an AEM on mine. No problems fitting, you can't tell it is there, can't hear it at idle or low curse speeds, but as soon as you go WOT and pass around 3k rpms, it sounds like a freaking Habuza is stuffed under my hood. Crazy man.
#258
There is a guy around here with an Ingen and his is loud all the time. Also loader than mine at WOT, though I think his is getting towards the point of being too loud.
#259
no name (injen imitation)
i purchase the injen imitation on e-bay the ones with no name and i disconect the battery completely for 2 hours when i reinstalled everything after a half hour to one hour run check engine light with codes p0103, p0101, p0172 i read here to cut the small part of the intake and that will fix the problem any help is apreciated. thanks in advance.
#260
use a dry filter, I have run the AEM and I am now running a JBP intake with an AEM dryflow filter. I haven't set any check engine lights so far. I now wish I had my AEM back as well.
#262
Also, an interesting fact for everyone. Make sure you use a large cone filter on your intakes. Use as big as you can get to fit down there. We had my car on the dyno all day yesterday trouble shooting a crazy AFR. Come to find out, my K&N was too small. We took it off for one pull w/ no filter and the overall AFR went from high 11's, low 12s down to consistant 9's with a flat AFR. Put a larger K&N cone on there and it jumped up to mid-high 10's, but the AFR stayed flat. Only took a few trims to even it out from 3K-7K. And the main reason I'm bringing up the Dryflow, is that I had a long discussion with two very reputable tuners yesterday for a while about filters after we found out my issue. Matt @ TTP has actually seen an 8whp difference on a larger displacement engine switching from a dry to an oiled filter. That's dyno proven.
#263
i have an injen has any body noticed like a whistle sound at about -10 boost for about the first 3 min of driving around and then goes away i've checked for leaks but everything seems to be ok?????
#264
Every car is different and will take a filter or a CAI different than the next car.
What doesnt make sense is the code you usually throw is a "Lean" code. Now if all the CAI opens the intake from stock ridged plastic to a 2.5" or 3" manderal bent metal tube (or whatever you have) how will a oiled vs. a dry filter matter? You are still opening the intake to roughly the same air volume that passes the MAF sensor.
Can anyone, thats defending the dry filter doesnt throw codes like the oiled filters do, tell me how that is possible?
#267
i have a question for someone who has an intake on their cobalt....i just put my intake on and it runs like ****....check engine light comes on....gets like 10miles 2 the gallon and doesnt have any horse power....what an i doing wrong?
cobalt
cobalt
#269
Just did the K&N air filter box butcher mod. and would recomend it to any one who is saving up for the 3" intake. Not only can you hear the sweet ass supercharger better but it also increased my psi in the lower rpm range.
Did you hook up the sensor ???
Last edited by MetalicSilverBullet; 07-30-2007 at 10:59 AM. Reason: Automerged Doublepost
#272
Use what you would like, but you will always make more power with an oiled filter that is properly maintained...
#273
Don't bother. No one listens. Regardless if it's a dry filter or an oil filter, you can throw a code. Temperature, elevation, run environment and build variables all play a part in whether or not you will throw the P0171 (lean) code.
#274
Matt at Tune Time Performance actually tested the dry vs. oiled filter on his dyno and lost power when he switched from the oil to the dry filter. People need to learn how to maintain the filter and they'll all be happier...
