Stage 3 Comp Cams
Old 01-03-2006, 05:44 PM
JCswoosher2's Avatar
Stage 3 Comp Cams
http://www.gravanatuning.com/applica...ft_Set_Stage_3.
did anyone see this? says its for Off Road Use Only and not highway. lol whattttttttt
Old 01-03-2006, 05:52 PM
wikkymaster's Avatar
i see they have them for the 2.2 also, i want to get cams in the future, but i dont want ones where the car dies out at idle
Old 01-03-2006, 06:32 PM
VictoryRed06's Avatar
thats sick...is anyone else gonna make cams for the ss?
Old 01-03-2006, 06:43 PM
player_1's Avatar
I know J-Body Performance has mad a stage 1 cam and I'm the prototype car for the Stage 2, both are street legal,
mine will be installed middle of next week.
Old 01-03-2006, 06:46 PM
LSX RWD S/C conversion
victory_red_SS's Avatar
Keep us updated on how this works out for you. I have till the beginning of March to get parts in order as that is when I tear down my block to start the 300+ build.
Old 01-03-2006, 06:47 PM
theBLUEone's Avatar
Nice
Old 01-03-2006, 06:58 PM
dirtySSout's Avatar
Unless this has a diff. lobe sep. then these are the same cams i posted about a long time ago. Why they named it stage 3, i don't know! they are the only blower cam they make. I talk to comp cams months ago about these and they are street legal. Just need a recal. to make it run better. Its designed to work with the stock valvetrain.
Old 01-03-2006, 07:10 PM
TurboTechRacing's Avatar
We are actually going to try the Turbo cams, Stage 2 and Stage 3 cams in the 2.2 ecotec drag cavalier we have this up coming season and see what actually works best.
We also sell them. Email us for a Cobaltss.net price!
Old 01-03-2006, 08:23 PM
FAST06SS's Avatar
What valvesprings are you going to use? Specs? Please don't say stock!
Old 01-03-2006, 09:44 PM
ralliartist's Avatar
i have to give you guys a review on the comp cams. i had a comp cam in my civic and i have to say that the cam was one of the best investments i made. i had a lot of head work that went along with the cam but man it dramatically increased my top end. now my idle was shot to hell. lol. it loped really hard, but i had the race cam and not the street cam. comp cams knows what they are doing!!!
Old 01-03-2006, 09:59 PM
dirtySSout's Avatar
Those are CompCams Part #113250 to be exact.
Old 01-03-2006, 10:02 PM
SS4LIfe's Avatar
i think they mean its not legal for use on highway, not it CAN'T be used on the highway.
Old 01-03-2006, 10:04 PM
dirtySSout's Avatar
Come again!?
Old 01-03-2006, 11:53 PM
We carry a full line of valve train parts. We will be using our dual valve spring with our special swirled stainless steel valves
Old 01-04-2006, 12:10 AM
Tofu's Avatar
Any word on when the valve springs/valves will be released to the public? I would be very interested in your Turbo cam set-up...that's a very nice/broad powerband according to your site!
Old 01-04-2006, 11:24 AM
spooler's Avatar
I have the JBP stage 1 cams for ages now. I would consider the stage 2 cams if they didnt release them right after my stage 1 cams! the cams made a big difference, but i would let someone install them who knows what their doing.
player_1 keep us up to date as to how your stage 2s come along!
Old 01-04-2006, 12:19 PM
player_1's Avatar
hey spooler, did you notice any differance in the idel?
Old 01-04-2006, 02:34 PM
theBLUEone's Avatar
For our cars would we get the "blower" grind if not can we use Stage 3?
Old 01-04-2006, 03:26 PM
celicacobalt's Avatar
wouldnt it cost us like $1000.00 to get these installed since they have to pull the engine?
Old 01-04-2006, 03:35 PM
Dman's Avatar
you shouldnt have to pull the motor to remove the head
Old 01-04-2006, 05:01 PM
^ Correct, it is far easier then doing a cam install on the 2.4L cavalier engine
Old 01-05-2006, 11:02 AM
ok how much for an estimated install
Old 01-05-2006, 12:52 PM
Vita's Avatar
aren't these the cams for the 2.2?
i think this topic has been visited, and that the 2.0 has one cam longer than the other, and these won't fit/work properly...
Old 01-05-2006, 02:00 PM
memphisr24's Avatar
I have no clue what cams do. All I know is that they make more hp and good top end. Could someone tell me what cams will do to the car?? Thanx
Old 01-05-2006, 02:16 PM
Rusty's Avatar
Camshafts (or cams) are what control your intake and exhaust valves in each cylinder.
Cams are driven by the timing belt. When the cam turns, it closes the exhaust valve, and opens the intake valve...or vice versa. This is all dependent on the timing and tuning of the car. The cams are ground to certain parameters that determine the length of time that each valve is open and the timing in which they close/open. As you probably know, for combustion in a cylinder, air and fuel are let in through intake valve into the cylinder. Then it closes and the spark plug goes off as the piston pushes the air/fuel up, creating combustion. Then the exhaust valve opens, exhaust gases escape and the piston is pushed down.
Aftermarket cams are designed to allow more air/fuel into each cylinder, usually at higher rpms. The more radical the cam, the better top-end performance you have, because the cams are then designed to be running at 5000+rpm or whatever. This usually results is poor idle quality. For example, when you go to the track and see pro street cars run, the idle sounds like its either going to die, or its real "lumpy." That means they have a very aggressive cam.
I hope that answered your question.
Quick Reply: Stage 3 Comp Cams
