Timing Chain Tensioner: The REAL How-To - Cobalt SS Network
2.0L LSJ Performance Tech 205hp Supercharged SS tuner version. 200 lb-ft of torque
Technical Discussions ONLY!
Thread Tools Search this Thread
Old 03-20-2012, 10:50 AM   #1
When switching to the new style tensioner, do NOT just plug and play the new one. Removing the tensioner creates enough slack in the chain for the engine to skip timing on startup. This can especially occur if the cams are resting in a position where they are sprung against each other. I tried this method because many on this forum have tried it with success, but they were very lucky.
If you want to do this right:
-remove the valve cover
-place a zip tie through one of the bottom holes on the intake cam sprocket around 7 o'clock
-wrap it around the chain under the exhaust sprocket, and tighten.
-then when you remove the tensioner, the chain is still in tension and will not skip timing.
-install new tensioner and remove zip tie
-install valve cover.
Perhaps this should be a sticky, because it seems to be the consensus on this forum that you can simply unscrew the old one and put the new one in. I just spent $500 in parts to fix my bent intake valves which was the result of using this method. A forum member suggested my timing chain may have possibly stretched, so I bought a new one. I measured the new against the old, and they were identical, so that is not the source of error here. It is the procedure. I hope others can learn from my mistake. If you lack the ability to do a head change yourself, this could end up costing you at least 3-4 times as much as it did me should you use the plug and play method.
SaberD is offline   Reply With Quote
Old 03-20-2012, 10:53 AM   #2
07LSJ's Avatar
Nice write up, i've seen some crappy ones before
07LSJ is offline   Reply With Quote
Old 03-20-2012, 09:06 PM   #3
^I agree...
After all the posts I read on here about"oh just take out the old one and pop in the new one"
I didnt believe it so I went to the local pick and pull and tried a few to see how the timing chain reacts when you take the tensioner out. 2 out of 3 fell off the bottom sprocket. One was tight enough it moved a bit but not enough to fall off. So those 2 engines could have been catastrophic failures.
I used a flat blade screwdriver on the tensioner guide and that worked to keep the tension but I like this idea.
cavfiredesire is offline   Reply With Quote
Old 03-20-2012, 09:10 PM   #4
advise's Avatar
Images: 161
you forgot to add in that you have to press on the chain guide to release the new tens.
advise is offline   Reply With Quote
Old 03-20-2012, 09:46 PM   #5
?Thats if you have it in the locked position but you can leave i in the extended position just fine.
Old 03-21-2012, 01:12 AM   #6
Gelladuga69's Avatar
Do you wanna do mine for me, Saber?
Gelladuga69 is offline   Reply With Quote
Old 03-21-2012, 12:48 PM   #7
Quote:
I can in a couple weeks. I have like half of my tools at a friend's house right now though. We are chainging out the clutch in his s2000, and waiting on parts at the moment. Send me a pm in a couple weeks if you are still interested, and I'd be happy to help you out.
Old 03-21-2012, 12:53 PM   #8
Post = Profit. Umad?
Images: 1
idk i just did it the simple way at least 8 months ago and nothing's happened. just unscrewed the old one... screwed in the new one! guess i'm one of those lucky few huh
riceburner is offline   Reply With Quote
Old 03-21-2012, 12:59 PM   #9
same here, but hell even my new CEd tensioner makes the same/simular noise my old one did, but just not as loud and it does go away. i only get the noise after its sat for more than 5-6 hours and it usually only last the first 3-5 miles you drive the car, its not a constant noise, just at idle. prolly just another "cobalt" thing lol.
sick CCSS is offline   Reply With Quote
Old 03-21-2012, 01:02 PM   #10
Sub'd
tbellazzi is offline   Reply With Quote
Old 03-21-2012, 01:29 PM   #11
ItalianJoe1's Avatar
It depends on where the cams land and how much you move everything when you take it out.
I always pull the valve covers, it's too easy to remove and not worth it to skip and end up with bent valves. I usually turn the motor over by hand until I can safely back it off a tad and get some slack on the tensioner side of the chain. That way you know when you release it it won't jump. Even with the valve cover off, if it jumps the only fix is pulling the front cover and resetting the timing properly, which is much more time consuming.
All in all, if this is something that you don't understand, i'd take it to someone who does. Too much risk if something happens to make it worth doing wrong. It's not a big job but carries a pretty big risk.
ItalianJoe1 is offline   Reply With Quote
Old 03-21-2012, 03:12 PM   #12
mrbelvedere's Avatar
Quote:
wrong
Quote:
wrong
the new tensioner dosent need to popped its a hydraulic tensioner
you do not need to pull the front cover to time a lsj there is a tdc mark on the front cover and a mark on the dampner
if you remove the old tensioner and it jumps time then you need to replace the timing chain and gear set because it is stretched beyond limits and the new tensioner will be 100% extended and not capable of doing its job properly by keeping enough chain tension not to mention the excesive loose chain will trow the cam timing off
mrbelvedere is offline   Reply With Quote
Old 03-21-2012, 03:54 PM   #13
Quote:
Originally Posted by mrbelvedere View Post
if you remove the old tensioner and it jumps time then you need to replace the timing chain because it is stretched beyond limits and the new tensioner will be 100% extended and not capable of doing its job properly by keeping enough chain tension not to mention the excesive loose chain will trow the cam timing off
I bought a new chain, and the length of the old one was identical to the new. it was not because of a stretched chain.
Old 03-21-2012, 04:12 PM   #14
your gear set was worn which isent that common it mainly the chains that wear out but reguardless they should be changed as a set
Old 03-21-2012, 05:02 PM   #15
You can line up the bottom pulley, but how can you see the colored mark on the gear? You could easily be off a tooth on the bottom pulley and the top would still look right. Not worth the risk IMO.
Old 03-21-2012, 06:06 PM   #16
With the new chain on and the tensioner out, it hangs past the crank sprocket enough for the crank to rotate, and enough for the rollers of the chain to come unseated from the vallies of the crank sprocket teeth.
If the tensioner is installed when the chain rollers are above the teeth on the sprocket instead of above the vallies, when the engine is started, it WILL skip several teeth. It is quite obvious this is what happened.
I was even able to repeat this several times rotating the engine by hand without touching the chain. I even conducted the experiment with the old chain before i took it off. I had the exact same results with the new chain.
The sprockets looked practically new. If a completely stock engine needs a new sprocket set or timing chain at 65k, that is a serious design flaw, and I mean very serious. Timing chains typically last the life of the engine, and the sprocket sets should too. I'm talking 200,000+ miles.
The only reason why the chain would stretch excessively or excessive sprocket wear occuring would be due to modifications:
-stiffer valve springs
-higher lift cams
-higher rpm
-basically anything that allows the rpms to accelerate faster like an aluminum flywheel for instance
Old 03-21-2012, 06:19 PM   #17
I pulled out the old, put it the new. It runs great.
drumrush is offline   Reply With Quote
Old 03-21-2012, 08:19 PM   #18
Quote:
If you're being serious, I'll throw like $50 your way for your time.
Old 03-21-2012, 08:29 PM   #19
Supporting Vendor
Quote:
ditto x 100 installs.
Powell Race Parts is offline   Reply With Quote
Old 03-22-2012, 12:49 AM   #20
spin the intake cam to its install postiton aka as the relaxed positionspin the exhaust to its relaxed position ensure the the tdc markd are lined up pull the chain around to where the colored links need to be for the cams install intake cam gear with refrence marks line up then do the same for the exh cam and rotate the exh cam back into the cam gear thats the only way i do is with the cover on never had a problem but the more you do the easier it is to do i actulay seen how to do it in the gm sportcompact build book 3rd edition ive even had to time a couple of them by counting links because the anodized color on the refrence links was gone its 16 links between for the cam gears
Old 03-22-2012, 01:02 AM   #21
-higher lift cams
-higher rpm
i have seen the gears worn and the chain been just fine or the chain stretched and the gears are just fine on 60k engines a couple of them were never driven hard either ive pulled coveres on 110k plus engines and poped the tensioner out and there be very little slack in the timing set i think it is more luck of the draw on that but i do know that if the chain hangs off the crank gear far enough that either the chain is shot or the gears are shot and the stuff needs to be replaced and if the chain is hanging off the the crank gear far enough for it to jump time the tensioner will be extended all the way and wont be ably to keep propper tension on the timing set and that will cause problems when you install a new chain and gears the there is very little slack in the timing set so little that it can a pain to get the tensioner back in
Old 03-22-2012, 04:44 AM   #22
Images: 200
My Chilton manual gives some fairly explicit prep and install instructions, to each their own but I'll be doing this one by the book.
OttawaMark is offline   Reply With Quote
Old 03-22-2012, 10:23 AM   #23
lol yeah im being serious. is it so uncommon for people to help out other forum members here? but like i said, i wont have my tools for a while, so send me a pm in a couple weeks.
Old 03-22-2012, 01:26 PM   #24
So overall on the average start to finish how long does it take to change the tensioner
bigjacksauto is offline   Reply With Quote
Old 03-22-2012, 02:10 PM   #25
Quote:
I am assuming that this link would cover all the ecotec motors?
http://www.crateenginedepot.com/pdfs/12608580INS.pdf
Last edited by bigjacksauto; 05-03-2012 at 10:28 AM. Reason: Automerged Doublepost
Thread Thread Starter Forum Replies Last Post
Akron/Canton Cobalt Meet 06MetallicBalt Mid East 7 06-14-2016 03:17 PM
Slidell, Mandeville, and Chalmette car shows Fearedbynone South Central 1 04-14-2016 04:25 AM
Clicking Noise biniecki Problems/Service/Maintenance 8 10-25-2015 03:23 PM
2.0 LSJ Engine: 2006 G85 Red SS, With TVS SSLOW06 Complete Cars 1 10-01-2015 08:21 PM
For Sale 2006 Cobalt LS (SS Upgrades) Car or Partout dieGone Complete Cars 0 10-01-2015 07:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
