TVS 1320 Ported vs Non-Ported (DYNO)
euthanasia cams? I like it. Get the exhaust all set and done first, or build the header to the cams please. I want to see you show what cams can really do and get this thing to the 400 wheel range (or more if you rev it)
think 80% css.net are in for the m62 results if money is issue 2 dollers from supporting members should add up quick and those who chipped in get to see the results. I strapped a 2.4 on this blower with meth and if it wernt for my more than worn belt it still be on the car but 2.55 was in hand so I said owell lets tune on this. If this port job is this hyped up then the small pulley m62's should deff gain from this service.
screw NB's. Level Zero Motorsports Be a man. It will be street able. At least it is considered streetable by the guys who run them on 2.2's with solid upper and lower mounts.
I run the bwoody solid mounts now, and its a streetable setup...
I like the price and idea... considering the spare block is gonna go to a machine shop anyway... this sounds like a fantastic idea.
my only concern is how bad it will vibrate the cabin. When euthanasia tossed NB shafts in... it made your teeth shatter cuppled w/ the bwoody solid mounts.
#45
If you plan on driving the car anywhere but a racetrack, and anywhere with red lights I'd advise against the LS4 TB its jumpy as **** and a real headache to deal with on a daily basis
