TVS 1320 Ported vs Non-Ported (DYNO)
#101
#103
I agree, but 2-3k is a lot of funds to a majority of the newbies that jump in here talking about wanting big power. I'm not sure what the total cost would be to properly run a TVS 1900, the 2-3k was not saying thats what it would cost.
#104
You'll easily put 2k into the headwork alone to make a TVS 1900 work
Machining, Porting + golf ball effect (youtube it) - This alone is over $1000
Larger valves (not the .5+ crap)
Cams
Springs/Retainers
You'll need run a 3.6 pulley, a 2.4L or larger, to attempt to maintain under 21 PSI.
The TVS 1320 on a setup like the above, with 11:1 CR or greater will net 500whp+.
Make the head flow, run as much displacement and compression as you can, and only then will you start making what the K series guys make w/ a blower.
#105
True
Cams
Springs/Retainers
Cams
Springs/Retainers
#106
is this true? has this happened before? i thought the TVS 1320 was only a minor upgrade over stock in terms of how much power it can make. what all mods do i need to make 500hp with a TVS 1320? i thought it was the TVS 1900 that could make that much power....not the 1320....
I made 423whp on a TVS 1320, and so far only one other guy has made 440ish on a TVS1320 w/o nitrous as well.
I made a thread describing it.
#108
#109
The following 2 users liked this post by 07blackg5:
ECaulk (01-19-2017),
Slowbalt2000 (01-19-2017)
Isaac Lewis (01-19-2017)
#115
Yeah...
Especially the blower grind cams available off the shelf.
ZZPs artificially large ZZP S3 is 216/224 @ 1mm and .424/.437 lift, 113 LSA
and
OTTP
S4 222/222 @ .050" .456"/.456" lift 114 LSA
The dimpled port effect in this one comparison video I watched on youtube showed large gains past .500 LIFT.
https://youtu.be/U6v2wpk4mjo
Was talking to Trevor last night... what if... we just went crazy and made a .500+ lift cam.
and
OTTP
