07blackg5 Build Thread. Operation Moneypit
#115
lol your doin a good job, trust me id be complaining and getting infractions if i didnt like something here. I wasnt nearly as meticulous when I rebuilt my LE5 last year, i was tired, fresh out of surgery, fed up with the problems i was having with it and just wanted the car back. I honed the block with my flex hone, sanded the deck with a flat block of glass and 600 grit to clean it off and get a decent finish for the head gasket, and measured the bearings and rings and reassembled everything after washing the block out thoroughly. I spent 3 weeks waiting for a tap and drill bit for the absolutely retarded thread size of the piston oil squirters which stripped out and had to be drilled out.
#122
The guy just blasted off all of what was included in my quote. I am going to work out the details with them on sat. It's the shop that Arm recommended to me/uses (have done many ecotecs), so I would assume they know what's up.
I also drilled and tapped my manifold for a bleeder port. ZZP stealth has a fill cap and is very easy to bleed, so they recommend tapping the manifold for the bleeder. makes sense because it is the highest point of the system.
Marked by their procedure.
The crease seemed like a better point than the cross, so I punched my mark there.
Drilled a small pilot hole to reduce the risk of the drill creeping
Full size hole
1/8 NPT tap and drill bit
Tapped
You can see the location here. The hole is slightly off the very highest point, but it is very close. The manifold is slightly off angle so it looks a bit over-exaggerated, but it's pretty damn close.
I still need to clean the manifold, but I threaded in the nipple to see where I was at. It is snug here, but not vertical. once I add thread sealant and tighten it down, it should tighten up vertical. I just didnt want to tighten it down too much and loosen the threads.
Full size hole
Tapped
#125
i got it new from mongo after I smashed up the original one I had haha. The cores had metal shavings in them and were basically spot welded in with rust. I had to tighten down the hose clamps so much to keep them from sliding off that I collapsed the end of 2 cores. The fins were salvageable, but as I was cleaning them I realized that I has effed up the core ends. it was mild enough damage (didnt even notice until I was all done) that it probably would have been okay, but I didnt want to risk it.
I just said eff it and got a new one. It was an expensive mistake haha
