2007 2.2 L61 Revisions
Summary of changes to the 2007 model L61
Wop
Wop
2007 Ecotec 2.2L I4 ( L61 )
ECOTEC 2.2L I4 (L61) CAR AND TRUCK ENGINE
2007 Model Year Summary
• Gen II Engine Block
• Cylinder Head Improvements
• New Camshaft Design
• E37 Engine Control Module
• 58X Crankshaft Reluctor Ring
• Digital Crank and Cam Sensors
• Individual Coil-on-Plug Ignition
• Vented Starter Solenoid
• New MAP Sensor
• New Intake Manifold Seals
• New Oil Filter Element
• Improved Emissions Performance
Full Description of New and Updated Features
Gen II Engine Block
The Ecotec 2.2L starts with a refined engine block, introduced for 2006 with the Ecotec 2.4L VVT (RPO LE5). The Gen II block was developed with data acquired in racing programs and the latest math-based tools. Both the bore walls and bulkheads, or the structural elements that support the crank bearings, have been strengthened, with only a minimal weight increase (approximately 2.5 pounds). The coolant jackets have been expanded, allowing more precise bore roundness and improving the block’s ability to dissipate heat. Coolant capacity increases approximately .5 liter.
The cylinder block is the engine’s foundation, and crucial to its durability, output and smooth operation. For GM, the common Gen II Ecotec block increases assembly efficiency. For the customer, the result is more efficient cooling, more strength to accommodate additional power, as in the new Ecotec 2.0L direct-injection Turbo (RPO LNF) and better noise, vibration and harshness control.
The Ecotec 2.2L also benefits from cylinder head refinements introduced on the 2.4L VVT. The exhaust ports have been enlarged slightly with machining improvements to expel exhaust gas more efficiently. Both engines share a common nodular cast iron exhaust manifold, chosen for its durability and sound-deadening properties. The improvements to the cylinder head increase Ecotec 2.2L horsepower slightly in most applications (see specs).
New Camshaft Design
The exhaust cam has been re-profiled to take advantage of refinements in the cylinder head. Maximum exhaust valve lift does not change, but duration increases slightly. The cams also feature a new 4X timing reluctor, replacing timing sensors previously contained in the ignition-coil cassette (see Individual Coil-On-Plug ignition, below). The powder metal reluctor wheel is pressed onto the camshaft at the rear. The 4X reluctor improves ignition timing accuracy and maintains precise consistency over the life of the engine.
Individual Coil-On-Plug Ignition
The Ecotec 2.2.L is equipped with individual coil-on-plug ignition, or four separate coils. Each coil sits directly over a spark plug, with no wire in between. Previous Ecotec 2.2Ls had two coils in a single cassette, with each coil shared by two spark plugs. Individual coil-on-plug delivers maximum voltage and the most consistent spark density. The 2.2L’s cast aluminum cam cover has been redesigned to accommodate the four coils.
An advanced controller manages the multitude of operations that occur within the Ecotec 2.2L every split second. The E37 is the S-3 Controller within GM’s new family of three engine control modules (ECM) that will direct nearly all the engines in Powertrain’s line-up. The E37 is the high-value variant, yet it’s anything but basic. It features 32-bit processing, compared to the conventional 16-bit processing in previous Ecotec 2.2Ls. It operates at 59 MHz, with 32 megabytes of flash memory, 128 kilobytes of RAM and a high-speed CAN bus, and it synchronizes several dozen functions, from spark timing to cruise control operation to traction control calculations. The E37 works roughly 50 times faster than the first computers used on internal combustion engines in the late 1970s, which managed five or six functions.
The family strategy behind GM’s new ECMs allows engineers to apply standard manufacturing, software and service procedures to all powertrains, and quickly upgrade certain engine technologies and calibration capabilities while leaving others alone. It creates both assembly and procurement efficiencies, as well as volume sourcing. In short, it creates a solid, flexible, efficient foundation, allowing engineers to focus on innovations and get them to market more quickly. The family of controllers means the ECM and corresponding connectors can be packaged and mounted identically in virtually every GM vehicle. Powertrain creates all the software for the three ECMs, which share a common language and hardware interface that’s tailored to each vehicle.
The E37 also applies a new, rate-based monitoring protocol sometimes known as run-at-rate diagnostics. Rate-based diagnostics improve the robustness of the Onboard Diagnostics System (OBD II) and ensure optimal performance of emissions control systems. The new software increases the frequency at which the ECM checks various Ecotec 2.2L systems, and particularly emissions-control systems such as the catalytic converter and oxygen sensors. Rate-based diagnostics more reliably monitor real-world operation of these systems, and allow regulatory agencies to more easily measure and certify emissions compliance.
The Ecotec 2.2L has an advanced 58X crankshaft position encoder to ensure that ignition timing is accurate throughout its operating range. The 58X ignition system uses a unique crankshaft ring and sensor to provide the new E37 ECM more immediate information on the crankshaft’s position during rotation. This allows the controller to adjust ignition timing with greater precision, which optimizes performance and economy. Engine starting also is more consistent with reduced crank time. The powder metal 58X reluctor ring is bolted to a crankshaft counterweight.
New digital sensors are common with the Ecotec 2.4L VVT and, with the 4X intake cam and 58X crank reluctors along with the new E37 ECM, they complete the ignition timing loop. This dual-position sensing system ensures extremely accurate timing for the life of the engine.
A new starter solenoid helps ensure starting performance in extreme cold temperatures. The solenoid case now has a micromesh-covered vent and an O-ring between the case and the starter motor. The mesh protects the solenoid from debris particles but prevents moisture buildup in the case. When the Ecotec 2.2L is warm, any moisture on the solenoid evaporates through the vent. The vented solenoid virtually eliminates the possibility of cold-start problems associated with solenoid icing.
New MAP Sensor
An advanced manifold absolute pressure (MAP) sensor completes upgrades to the Ecotec 2.2L’s control system. The MAP sensor is a variable resistor used to monitor the difference between atmospheric and manifold pressure, which tends to increase when the engine is operating under a higher load or at wide-open throttle. The ECM uses information from the MAP sensor to adjust spark timing and fuel delivery to optimize performance and minimize emissions. The new MAP sensor improves fidelity, or accuracy, and takes full advantage of the E37 ECM’s capabilities.
The Ecotec 2.2L is equipped with new intake manifold and throttle body sealing gaskets manufactured from a fluorocarbon material. The new gaskets are more resistant to most chemicals, for maximum durability, and particularly impermeable to hydrocarbon molecules. Gasoline vapor cannot penetrate the new seals, virtually eliminating evaporative emissions.
The paper element in the Ecotec 2.2L oil filter has been improved. The engine’s innovative filter design uses a replaceable cartridge without the conventional metal filter can, which traps waste oil that can not easily be removed. The cartridge can also be changed from under the hood, without getting under the car, and it virtually eliminates spillage during replacement. The new element filters particles from the oil more effectively without disrupting oil flow.
The Ecotec 2,2L now meets BIN5 tailpipe emissions mandates in all applications. To achieve this standard, the mix of precious metals in the catalytic converter has been reformulated. Metals such as platinum, palladium and rhodium in the converter’s catalytic substrate create the chemical reaction that turns the majority of exhaust emissions into harmless gases and water vapor. With the new intake sealing gaskets, the 2.2L also meets PZEV (Partial Zero Emission Vehicle) Enhanced Evaporation standards.
• New MAP Sensor
Gen II Engine Block
New Camshaft Design
New MAP Sensor
PS
2007 2.2 Horsepower Torque Levels (all SAE CERTIFIED in 2007) are as follows:
Application: Horsepower: hp ( kW ) Torque: lb-ft. ( Nm )
Chevy Cobalt 148 hp (110 kW) @ 5600 rpm 152 lb.-ft. ( 206 Nm ) @ 4200 rpm
Pontiac G5 148 hp (110 kW) @ 5600 rpm 152 lb.-ft. ( 206 Nm ) @ 4200 rpm
Chevy HHR 149 hp (111 kW) @ 5600 rpm 152 lb.-ft. ( 206 Nm ) @ 4200 rpm
Chevy Malibu 145 hp (108 kW) @ 5600 rpm 152 lb.-ft. ( 206 Nm ) @ 4200 rpm
Saturn VUE 144 hp (107 kW) @ 5600 rpm 149 lb.-ft. ( 202 Nm ) @ 4200 rpm
Saturn ION 145 hp (108 kW) @ 5600 rpm 150 lb.-ft. ( 203 Nm ) @ 4200 rpm
I like that the 2.2 is built off the same strenghts you can benefit from the 2.4. Honestly I know there are small differences between each motor but to carry uniqueness between each motor in terms of displacement is outstanding. The Ecotec is truely an awesome motor platform not to be underestimated.
I like how without throwing any hints out they say it can handle more power being thrown at it. Almost like they are begging someone to throw F/I at it.
Gen II Engine Block
Brian66 (12-21-2022)
Originally Posted by HackAbuse
If they even crack the E37 ECM before they crack the E16, I will ******* strangle someone
Originally Posted by Kahless
that ecu is even more complicated than the e16, wouldnt count on it
cant see past one bar of pressure.
I'm happy to see the L61 'catch up' with the advancements made in the other Ecotecs. But don't count out the existing engine...we've been cranking them up for years without issue. They just made an already good thing even better!
So with your expierience, do they normally fail at 250hp with stock internals, or how far can they be pushed?
I just dont want to listen to the sound of all four rods snapping simultaneously when I test the limits of my nitrous
My advice? Take the cash you save doing nitrous instead of a turbo, and put it into the motor. Then spray at will! I don't see anywhere where this revised L61 will have forged rods instead of powdered metal, so the nitrous 'fuse' will still be in there (or is it four nitrous fuses?)
i'd kinda like to see it when it does.
I'm old school
Pics of changes
The new valve cover with the new coil-on-plug ignition. The cover is very plain. It has no smooth edges or contoured surfaces. Its very angular and really not very pretty. And while the ignition system is better, it's just ugly.
The new E37 ECM. 32-bit processing, there ya go.
A new Brake line manifold, just something else I saw while poking around under the hood. The older models have the anti-lock brake unit located there, so I'm assuming the new cars have a different kind of brake system.
Originally Posted by joeworkstoohard
i was under the impression that was the same as the ECM in the current 2.4. which means you don't have to crack it... i only think that because it uses the newer diag port
Eww, I like our ignition better, its much more clean
WOT
LOL Hack stop being so paranoid, stick with a 75 shot or under like we've gone over and you're money. if you're really that worried like Bill said go and build your bottom end up and you'll have more peace of mind.
Sweet improvements for sure, stronger from the factory is what I like to hear.
