Base Model Sleeper build (long time lurker)
First of all I want to comment on what a great community y'all have here. I referenced this site numerous times while planning and doing my build. I have a base model 2006 LS which I have always enjoyed even before putting the M62 supercharger on it. Now that I have started modding I have become addicted. I have decided to share my build with y'all and following is a list of the main components that I swapped in.
Powertrain mods:
-M62 Supercharger (3.1" pulley)
-LSJ throttle body and intake manifold (Dual-pass intercooler)
-ZZP S3 heat exchanger
-650cc Bosch split-spray fuel injectors
-Magnaflow 2.5" cat-back
-ZZP 2.5" High flow cat
-KY Kevlar clutch, pressure plate, and slave cylinder
-Custom CAI
Suspension and bake mods:
-FE5 struts with YYZ springs
-FE5 Alloy front control arms with spherical CABS
-24 mm front sway bar
-Powell hardcore rear sway bar and under car rails
-Front slotted rotors with Hawk performance ceramic pads
-Powergrid end links
Interior mods:
-AEM analog wideband and boost gauge
-TWM short throw shifter
Up on stands and seats removed to install under car rails from Powell
Installing UCR
UCR Installed
Here the car is on jack stands utilizing the UCRs from Powell. The UCRs are great if you don't have a lift to get the car up in the air. Only have to use a jack once on each side and the Rails rest nicely in the jack stand's cradles.
On the left is my new Powergrid adjustable end links. On the right is the stocker
Here is a picture of the stock control arm bushing. Lots of play and this one is torn.
Spherical TCAB from powell on the latest TC FE5 control arm
Stock and new control arms
Sway bar comparison
Front cradle assembly with newly installed goodies.
Sleeper status
Powertrain mods:
-Custom CAI
Interior mods:
Installing UCR
UCR Installed
Sway bar comparison
Sleeper status
If you jack your car up very much at all I would highly recommend them. Single point lift nub on each side so you only move the jack once. It also sits nicely in the jack-stand's cradle for a nice wide stable base that gives you more confidence when working underneath it.
I want to put a wider tire on it but I like the steelies for this build. If I put wider tires, with probably 17X8 wheels, then I'll upgrade the brakes. Upgraded disc in front to go with disc conversion in back so bias isn't way off but I'm not sure the best way to go about doing that.
But I might save that money and spend it on a Quaife LSD.
More urgantly I need a header, but I can't decide what type to get, as I'm still on the stocker.
jdbaugh1 (02-07-2016)
OrangeCoba
01-26-2016 11:31 AM
Bigslim
01-07-2016 08:10 PM
