camber kit?
Old 04-26-2007, 09:56 PM
Balt36's Avatar
camber kit?
i have an 05 ls and i bought the eibach sportlines...where can i get a camber kit to get them installed? any help would be great
Old 04-26-2007, 09:57 PM
CTORANGESC's Avatar
Any alignment/Tire shop should be able to install it for you
Old 04-26-2007, 10:04 PM
blktrax's Avatar
You dont need them you need what the alignment guys call, "Crash bolts" or "Eccentric Bolts".
Any good alignment shop will have them for about 10 to 15 per bolt.
I only put one bolt per side and kept one stock bolt per side. I have camber adjustment from the positive side of stock to up to 2.2 degrees negitive camber.
Your stock bolts shoud allow enough adjustment fora stock alignment, replace the bolts if youre wanting to do something specific like autocross. I run 2.0 neg camber for autocross and back it off to 1.2 for daily driving.
Old 04-26-2007, 10:52 PM
disposable_her0's Avatar
im just gonna lower my car myself and get it aligned at a shop...including the camber kit put on
Old 04-26-2007, 10:54 PM
I'm old school
Halfcent's Avatar
No, no, no. FE1 suspension (what your car has) has zero camber adjustability. And you can't get a cam bolt to fit. The only thing adjustable on your car is the toe via the steering tie rods.
I have Eibach.
I bought the cam bolts in advance in case I needed them.
I put the springs on myself (and wrote a how-to on it).
I had it aligned afterward at the dealership. There is nothing to adjust.
The only way you can change camber would be cut bigger holes into your struts and strut towers allowing some movement of the bolts. And you don't need or want to do that.
Please try a search before making a new thread. There are LOTS of threads on this topic. Like this GREAT BIG STICKY thread right in the suspension forum:
https://www.cobaltss.net/forums/suspension-67/bump-stop-cutting-alignments-camber-kits-lowering-springs-53340/
Old 04-26-2007, 11:01 PM
blktrax's Avatar
Halfcent, when we had the stock lower strut bolts in, youre right there wasnt much adjustment but there is some about .3 degrees.
I can get the bolt size tommrow at work, we didnt have to round out the holes we used just the upper of the two lower strut bolts, left the lower bolt stock. I'll have the pic as soon as i get the wheel off for this weekends autocoss to get me back to 2.0 neg.
Castor is only adjustable by rounding out the upper strut mount bolts front to back, aggreed not that you need to do that.
Old 04-27-2007, 09:25 AM
blktrax's Avatar
Here a picture of the bolt, 2 needed, and the GM Part Number.
Old 04-27-2007, 09:44 AM
SSKevinSC's Avatar
Cool
I have Eibach.
https://www.cobaltss.net/forums/showthread.php?t=53340
^^^^^^^^^^Agreed^^^^^^^^^^^^save your money,No camber kit installed with my Sportlines
Old 04-27-2007, 09:49 AM
kenhebe's Avatar
Eibach makes a camber kit. Go to www.tirerack.com IT is about $50
Old 04-27-2007, 01:58 PM
blktrax's Avatar
To reitterate, you only need a camber bolts if,
A) If the stock bolts won't allow for a sock alignment, or
B) If you want a specific Alignment setup with adjustability.
eibach's camber kit is the same thing, bolts, thats it.
You can see the cam bolt in the top hole, and the stock bolt in the lower hole. No rounding of the holes were nedded, they were snug and a little grese on the cam made them slide right in.
Old 04-27-2007, 11:07 PM
PatDamanCobalt's Avatar
I had an alignment after i put my tenzo's put on. I was charged an additional 18$ to adjust the camber on the passenger side. Is this what they did?
Old 04-28-2007, 08:10 AM
denniss's Avatar
Camber is adjustable, at least GM Service Information thinks so.
Document ID# 867666
2006 Chevrolet Cobalt
Front Camber Adjustment
Loosen both strut to knuckle nuts just enough to allow for movement.
If the strut has not been modified previously, perform the following steps before continuing with the wheel alignment:
2.1. Disconnect the strut from the knuckle. Refer to Strut Assembly Replacement .
2.2. File the lower hole until the groove of the stamped ring around the hole.
2.3. Connect the strut to the knuckle. Refer to Strut Assembly Replacement .
Adjust the camber to specification by moving the top of the wheel in or out. Refer to Wheel Alignment Specifications .
You would only need a "camber kit" if you wanted to change camber for competition, like BLKTRX said.
Dennis
Old 04-28-2007, 11:59 AM
I'm old school
Halfcent's Avatar
Read that again. It says you have to remove metal. You have to make the hole bigger. That's what I'm talking about. You can't adjust these struts UNLESS you cut holes. Which means, you don't have to adjust them unless you bent something.
Old 04-28-2007, 12:52 PM
denniss's Avatar
The point I am trying to make is the camber IS adjustable. Yes, you should not need to make the adjustment under normal circumstances, but lowering a car can and does change suspension angles possibly requiring a camber adjustment. The Pro springs might not need alignment, but some of the other springs that lower the car more might need alignment. Adjusting camber is also needed to get the best handling for auto-cross or road racing.
Dennis
Old 04-28-2007, 03:13 PM
Blackout06LS's Avatar
I got a alignment kit I bought from PTuning.com.
I didn't use it. Did my own alignment, and yeah still was dead on.
I'll sell you mine if you still want it $30 shipped.
Old 04-28-2007, 03:22 PM
laserblue2006's Avatar
I have Eibach.
i was thinkin you couldnt adjust the camber. and halfcent knows his stuff so i would listen to him.
Old 04-28-2007, 04:43 PM
denniss's Avatar
Why does it seem whenever I post it gets confrontational? I don't doubt halfcent "knows his stuff", in fact I believe he is one of the most knowledgeable people on this forum. Does that mean I know nothing? I think 8 years as a GM technician (and 22 years before that as a body tech for other makes) would qualify me to post information out of the GM service manual and maybe have people believe me? I am wrong about a lot of things, but I try to not post if I am wrong about something. Cobalt camber can be adjusted if the need arises using GM recommended procedures. Sorry if I stepped on anyones toes, and sorry about the rant.
Dennis
Old 04-25-2022, 06:00 PM
Bmax84's Avatar
What about these? https://www.maxpeedingrods.com/produ...RoCl8kQAvD_BwE
Old 03-08-2024, 10:08 AM
Triptiatom's Avatar
Triptiatom
Everything is very open with a precise clarification of the issues. It was definitely informative. Your website is very useful. Many thanks for sharing!
Old 03-08-2024, 10:09 AM
Triptiatom's Avatar
Triptiatom
Thanks designed for sharing such a good idea, article is good, thats why i have read it fully
Old 03-08-2024, 10:10 AM
Triptiatom's Avatar
Triptiatom
If you would like to get a good deal from this paragraph then you have to apply these strategies to your won website.
05-28-2022 03:47 AM
dennis69
10-20-2015 04:49 PM
thewafflesareburnt
09-30-2015 02:29 AM
09-28-2015 12:51 PM
metroplex
09-27-2015 07:48 AM
Quick Reply: camber kit?
