Cobalt Parts Interchangeability
Old 01-29-2010, 12:59 AM
  #251
Got2BeGT's Avatar
Originally Posted by HunterKiller89
a) yes
b) looks like the above kit includes this adaptor
c) this is ture, however some have also reported a substantial loss in low end power, so that power under the curve is almost exactly equal before and after. Some dont experience this though...be warned
b) yes, I see its included lol, but are they sold/made separately?
c) I wonder if that has to do with lack of tuning/not tuning at all...that much more air entering should require more fuel going into the engine, and if they aren't getting the extra fuel, that may be why theres decreased low end power
Old 01-29-2010, 07:22 PM
  #252
tru2nrtt777's Avatar
No, it is just like people who put 3" exhausts on cars with less than 250hp. It is all about velocity. At a low rpm you are not able to push enough air to make it want to keep flowing so it creates its own turbulence but when you hit high rpm there is enough velocity to make power because it is getting rid of the turbulence.. Same principle with the intake side although you are talking about vacum, not pressure. It really has nothing to do with it running lean, even tuned cars have the issue.
Old 05-23-2010, 01:05 AM
  #253
cobalt523's Avatar
it probably in the thread somewhere but dont have time to read it all, but how can i convert the rear drums on my lt to discs from an ss
Old 05-23-2010, 02:09 PM
  #254
RecklessL61's Avatar
do you have 5 lug or 4 lug
Old 07-05-2010, 09:36 AM
  #255
CaspertheCobalt's Avatar
Will a 2door body kit fit on a four door like this one? http://www.streetbeatcustoms.com/Vfi...CC2BC2/714795/
Old 07-05-2010, 11:39 AM
  #256
007CobaltLS's Avatar
The front clip is going to work no problem, the side skirts I believe will work, but the rear will not because coupes and sedans are different.
Old 07-05-2010, 02:07 PM
  #257
CobaltKatsu's Avatar
LNF intake mani, will it bolt right up to the 2.2? And would I have to get a different tb?
Old 08-31-2010, 05:39 PM
  #258
Fallout's Avatar
Have a question, does the 2.4 Head bolt to the 2.2 block?
Old 09-01-2010, 03:52 PM
  #259
Maven's Avatar
several variables , but easy answer is bolt to: yes, work properly no.
Old 09-24-2010, 12:53 AM
  #260
4bangerwut's Avatar
could i put lsj injectors in my 2.2? what are the stock lsj injectors? #39?
Old 11-05-2010, 10:33 AM
  #261
DFZ24's Avatar
quick question, i have try to go through everything and serch everything. I have SS/NA, would the SS/TC shift knob will fit or will bolt to mines?
Thank you
Old 11-07-2010, 03:35 PM
  #262
Maven's Avatar
no, shift knobs are completely different type attachment
check your email.
Old 11-30-2010, 01:12 AM
  #263
Harrison.j.c's Avatar
little question
hey i know it's a dumb question, but, whats the engine with the most hp and torque, you can drop into a 2010 cobalt ls??
Old 12-06-2010, 04:13 PM
  #264
kingg5's Avatar
lol its not a honda man...this question is pointless.
but the most power available stock in a cobalt is the 2.0 LNF turbo
Old 12-13-2010, 10:10 PM
  #265
Belto's Avatar
double checking, does the TC stock cat back fit the 2.2?
Old 12-14-2010, 12:49 PM
  #266
Maven's Avatar
no. different flange. needs proper flanger welded on
Old 12-14-2010, 01:14 PM
  #267
Belto's Avatar
thanx^^^
Old 12-21-2010, 03:29 PM
  #268
LAZ THE HUN's Avatar
Steering interchangeability and difference
Ok I could use a little help with this:
I have an 07 base model Cobalt (4 lug soft suspension).
My steering rack is going bad and needs to be replaced.
Are their any differences between a base model or an SS (tighter lock to lock maybe) and are the racks interchangeable??? The sport rack is less expensive from O'reily by $100 then the soft one, so if I could I would of course rather get the less expensive one?!?!?!? Any advantages to the SS again such as lock to lock, better quality, etc. (if it will work)..
THANK YOU
Old 01-05-2011, 02:28 AM
  #269
Tundraboarder666's Avatar
So according to the first post any year SS cluster will work on an 07 LS cluster... i don't think that's right.
Old 01-19-2011, 10:14 PM
  #270
Schneids's Avatar
05 ss cluster work on 05ls ??
Old 01-24-2011, 09:35 PM
  #271
kingg5's Avatar
yes
Old 02-14-2011, 01:54 PM
  #272
08_Slowbalt's Avatar
I'm pretty sure of this but I want to get some confirmation on it. Does a L61 2.2L from a Cavalier work in a 2008 cobalt? I know it wouldn't be exactly plug and play but I want to build up a motor for 300+whp so if I get a 2.2L L61 crank, block, and head from a cavalier will all the rest of my parts on my cobalt transfer to that block?
Old 09-06-2011, 11:28 PM
  #273
LTcobalt06's Avatar
just a few question for a new member a french one so sorry for my mistake
if i put some 2.4 piston w/ 11.4:1 compression in a 2.2 block that is basically a 10:1 compression
will i still have a clearace between valve and piston ?
will there be a hp gain ?
do i need to tune it after ?
does it work w/ a stage 3 camshaft ?
i need answer cause i don't want to spend money for something that's just don't work
thanks
Old 09-07-2011, 03:46 PM
  #274
Philswrath's Avatar
will an LNF downpipe fit on a 2.2
im gathering turbo parts and wanna clarify
Old 09-07-2011, 10:45 PM
  #275
Maven's Avatar
thanks
No, they wont even fit in the block.
LNF DP will only fit on a 2.2 if youre using an LNF turbo and manifold on the 2.2
Quick Reply: Cobalt Parts Interchangeability
