Cobalt Parts Interchangeability
Old 12-12-2007, 11:00 AM
  #101
CTSSBowtie's Avatar
Originally Posted by YellowLT
To Turn a 2.0 to a 2.2, All you need is the Crank, Rods, and Pistons.
That I did not know...
Kewl, thanx
Old 12-12-2007, 12:39 PM
  #102
YellowLT's Avatar
Kewl, thanx
The Blocks are identical. Check EcotecForum.com, They have a whole section to Hybrid engine combos.
Old 12-12-2007, 01:23 PM
  #103
awdish's Avatar
So I am able to buy the spoiler from the SS and place it on my LT? If so, can I buy the spoiler directly from a dealership? Or do I have to order online?
Old 12-12-2007, 01:26 PM
  #104
YellowLT's Avatar
Yup or you can swamp trunks, with some one here.
Old 12-12-2007, 01:29 PM
  #105
awdish's Avatar
Awesome, thanks for the quick reply!
Old 12-12-2007, 01:31 PM
  #106
umrdyldo's Avatar
Trunk swap is easy like 15 minutes and well worth it. People will be on both sides of that topic forever. Some call it "rice" some call it cool. You be the judge. Its unique, until the cop lights are blocked in your rear view
Old 12-12-2007, 03:11 PM
  #107
CTSSBowtie's Avatar
Thats why I'd rather have a lower wing... So I can see the pigs behind me.
Old 12-12-2007, 03:29 PM
  #108
NWAE Cobalt's Avatar
im trading a guy for his trunk with the wing....and he wants my wingless...and for the cops - thats why i have side mirrors
Old 01-07-2008, 07:03 PM
  #109
cobaltLS4dr's Avatar
The other problems you will likely run into is replacing or fabricating the protective plastic under the front of the car. I hate this plastic on all GM cars with such a passion. It is the most flimsy POS I have ever seen.[/QUOTE]
you have plastic under your car? mine doesnt have any plastic under it
Old 01-07-2008, 07:13 PM
  #110
you have plastic under your car? mine doesnt have any plastic under it[/QUOTE]
what plastic?? the air dam???
Old 01-31-2008, 12:03 AM
  #111
Tysis's Avatar
Hey I have a question. I read all seven pages and I think I got my answer from the first initial post listing the swappable parts, but I want to double-check and make sure. I've called GM and even they couldn't help me, and finally I got one of the Chevrolet mechanics (I work at a major Chevrolet dealership in Murfreesboro) to help me out. He said I shouldn't have a problem because the bore and some other stuff are the same, but I want to ask you guys since you seem to know a lot about Cobalts. Anyway, getting on with the question. I bought an 07 LS 2.2L L61 Cobalt, and I have seen the supercharger for the 2.2L advertised in their performance catalogs and on websites, but it was made for the 05-06 models, before the 07 came out. So I want to know if that supercharger will fit on my cobalt since I know they changed something for the 07 but I'm not sure if it affects the ability to add it or not.
Old 01-31-2008, 01:14 AM
  #112
avenger09123's Avatar
well man, I say a 99% yes for the supercharger to work on the 07 2.2s. The only significant change is that the PCM's on ours are different than the 05-06's. However since the GM dealership can tune it - theres nothing for you to worry about......anything you do to this car(especially after the 08 turbo comes out) that replicates the existing conditions already on an SS can be put onto our 2.2s as long as they have GM Dealerworld or Tech II access (or maybe hp tuners depending on what Cobalt_07 tells me about his tune coming up).
Old 01-31-2008, 03:26 AM
  #113
YellowLT's Avatar
You Have a part Number cause the kit you are referring to I believe is the one for the Cavy. However it should physically bolt up, but tuning is the issue.
Old 02-08-2008, 08:55 PM
  #114
tru2nrtt777's Avatar
I havent searched but by the post about the ss/sc tuning, does that mean I can get the dealer to remove the speed limiter? My car "soposively" tops out at 107 and doesnt even make it to 4th gear when @ WOT. I wouldnt know personally... ... ... but if I did it would really **** me off. Can the dealer remove such limit(or move it to the SS/SC limit of 155?
Old 02-12-2008, 02:08 PM
  #115
YellowLT's Avatar
You may be able to get them to flash the SPORT Package on there, BUT Only do this if you have new Tires. Factory ones shred themselves at 109. That means you dead. This will allow your car to do 120.
Old 02-12-2008, 10:15 PM
  #116
Sharpie's Avatar
Sorry to sound like a noob, but how do they use the tech II to tune them? Also can they 'tune' 2.2s?(2005)
Old 02-13-2008, 07:17 AM
  #117
YellowLT's Avatar
I never said tune. The Sport Package for the Cobalt moves the Governor up to 120 and Changes the Tire size to re calibrate the Speedo. Thats it. No TUNING
Old 02-13-2008, 04:01 PM
  #118
I have 245/45/17's that only have like 3k miles on them, I understand the reason for the limiter hence me waiting to bitch about it, lol. My stock fronts were shredded by 6k.
So there is no way to completely remove the limiter? It just pisses me off that my buddy kicks my ass as soon as we hit 107.
Old 02-14-2008, 03:04 AM
  #119
cobalt-z's Avatar
lol i can top out at 114 in my car. hehehe i luv it but iwish i could go faster to
Old 02-14-2008, 08:17 PM
  #120
What size tires to they reflash it to?
Old 02-15-2008, 06:28 AM
  #121
YellowLT's Avatar
The 16 inch Rims with the different tires. I forget.
Old 02-17-2008, 02:00 PM
  #122
I really need that too, i was even with a tibby up to 3rd gear and started pulling away, then the damn limiter hit and that bastard got me...
Old 02-17-2008, 04:39 PM
  #123
brandon2.2's Avatar
I read through a lot but there is just so much on this thread. SO quick question.....I want forged pistons but I want a 9.5:1 compression ratio. I have a 2.2L and I am going to turbocharge it. If I buy the Diamond Forged piston set which is for the 2.0 (same 86mm bore) and 9.5:1 compression, can I just get these pistons to achieve the 9.5:1 compression or do I need different connecting rods???
Old 02-17-2008, 05:49 PM
  #124
Good question, unfortunately I am not knowledgable enough to answer that for you.
Old 02-18-2008, 07:21 AM
  #125
brandon2.2's Avatar
ok thats cool, anyon else that might know?
Quick Reply: Cobalt Parts Interchangeability
