Cobalt Parts Interchangeability
#126
The connecting Rods will work. BUT I highly suggest new rod if your going FI. Plus it you already have the motor torn apart better to do everything at once.
#127
yea thats the plan. But I am buying connecting rods that say they're for the 2.2L, and I want the pistons that are for the 2.0 and 9.5:1, I am going with forged rods and pistons....I just had to make sure that if I bought connecting rods for the 2.2L, that pistons made for the 2.0L would work with those rods.
#128
From what I understand they arent physically different other than hardness but dont quote me, I thought it was the crank and the pistons that change the displacement.
#129
also I know that I am going to be going forced induction. if I wanted the supercharger from a 2.0L I need the supercharger, throttle body and intake manifold right? I just want to make sure.
#132
i Was Reading in the GM performance build book and it was saying to switch out the 2.2l61 header with a 2.0 header.? "For improved durability it is recommended to upgrade to
the production 2.0L LSJ valves or Ferrea (part number
F1963P intake and F1961P exhaust) valves." am i undertanding this right?
#133
#136
GM offers them.
If you put 2.0 pistons in a 2.2 without these rods the engine wont turn over.
Hey I have a question. I read all seven pages and I think I got my answer from the first initial post listing the swappable parts, but I want to double-check and make sure. I've called GM and even they couldn't help me, and finally I got one of the Chevrolet mechanics (I work at a major Chevrolet dealership in Murfreesboro) to help me out. He said I shouldn't have a problem because the bore and some other stuff are the same, but I want to ask you guys since you seem to know a lot about Cobalts. Anyway, getting on with the question. I bought an 07 LS 2.2L L61 Cobalt, and I have seen the supercharger for the 2.2L advertised in their performance catalogs and on websites, but it was made for the 05-06 models, before the 07 came out. So I want to know if that supercharger will fit on my cobalt since I know they changed something for the 07 but I'm not sure if it affects the ability to add it or not.
A supercharger will physically fit on an '07 2.2, but there is no way to tune the ECM.
You'd need to use a fuel controller, go with a piggyback or standalone of some sort.
well man, I say a 99% yes for the supercharger to work on the 07 2.2s. The only significant change is that the PCM's on ours are different than the 05-06's. However since the GM dealership can tune it - theres nothing for you to worry about......anything you do to this car(especially after the 08 turbo comes out) that replicates the existing conditions already on an SS can be put onto our 2.2s as long as they have GM Dealerworld or Tech II access (or maybe hp tuners depending on what Cobalt_07 tells me about his tune coming up).
You cant reprogram a 2.2 to think its supercharged.
The 2.2L61 , 2.0 LSJ and new 2.0turbo LNF all use completely different ECM's and only the LSJ's is tunable right now.
Also you cant install "anything that replicates the conditions of the SS". You can only upgrade to options for the car youve got. For example, most dealers wont or at least arent supposed to, reprogram an LS or LT for 17's or 18's because they arent an option, trhey are only available on the Sport/SS. For example a 2008 LS model doesnt even have 18" wheels as a possible selection in the BCM because there is no car with 18's right now.
Most dealers wont do this as GM will be unlikely to issue a VCI password to allow them to do so. GM wont issue a password because they have no way of knowing that youve got speed rated tires on your car, or that youll keep them.... So they dont allow it. Its a liability issue for GM
#137
#138
Moder Zogaz... So that is why they told me they "couldnt" change my limiter... But they did reset my speedo for my 17's which with those tires cover 3 milimeters more per rotation than stock SS/SC 215-40/18's. They set it to the same settings as those since they couldnt set it for my exact tires.
Not to put too fine a point on the subject but basically you can swap anything between all the levels of car and between the Cobalt and G5, its just a matter of how much work/parts are involved.
#139
Yeah, I knew that wouldnt change my limiter but shiot, I plan on having this thing til it runs into the ground, they should let me change the damn speed limiter.
#140
A co-worker of mine has an '06 sc/ss coupe and he had upgraded to stage 2. Will his stock exhaust fit my '08 lt sedan? If so, is it worth the effort to swap it? Thanks.
#144
#145
For the interior make a note that 4 door cars cannot use the A pillars in the 2 door cars without modification.
I know because I have an SS gauge pillar that I had to modify to fit in my fore dore.
#150
Here's a quick question, are the Ion RL and Cobalt SS/SC exhaust the same? Locally there's a guy that's going aftermarket and I might be able to get my exhaust from him if it's the same.
