L61/LAP Turbo/Super (Forced Induction) Build Thread
Old 07-20-2010, 08:23 PM
  #51
Pedobear's Avatar
yup.
Old 10-14-2010, 10:46 PM
  #52
Spanky's Monkey's Avatar
my updated thread ------>Clicky
Old 10-15-2010, 12:19 AM
  #53
Mr.N00bLaR's Avatar
I am no longer able to edit the original post.
Now that I think about, this should probably be stuck in the lap section as well or at least a link back to this thread..
Old 10-15-2010, 12:21 AM
  #54
that **** is so silly. oh well.
Old 10-24-2010, 11:48 PM
  #55
redcobalt07's Avatar
so question, does an 8pin LSJ throttle body need repinned if going into an L61 that is already 8pins?
Old 01-31-2011, 03:35 PM
  #56
Mr.N00bLaR's Avatar
Haven't made an update in a while.
Here's some good info on routing hoses for option b with HEs (with diagrams)..:
https://www.cobaltss.net/forums/2-0l...78/index2.html
Since I cant edit the original post anymore..:
Kind of specific but some turbo cam info: https://www.cobaltss.net/forums/2-2l...12/index2.html
Garret's turbo symptoms chart: http://turbobygarrett.com/turbobygar...s/symptoms.gif
Member opinions on supercharging: https://www.cobaltss.net/forums/2-2l...stions-238021/
stenguyen1's new build thread: https://www.cobaltss.net/forums/2-2l...thread-238062/
General l61 graph:
Old 04-04-2011, 12:49 AM
  #57
Mr.N00bLaR's Avatar
Update bump:
vash90909's progress thread: https://www.cobaltss.net/forums/2-2l...-build-240514/
redcobalt07's dual pass info thread: https://www.cobaltss.net/forums/2-2l...plates-244948/
conerboner's build thread: https://www.cobaltss.net/forums/2-2l...-boost-240401/
Don't remember if this is in here anywehre but...
ECOTEC build book links: GMTunerSource.com - ECOtec Build Book - Sport Compact Build Book
Old 04-04-2011, 12:51 AM
  #58
heathkidder's Avatar
i believe the wiring might be diff. from lsj to a 2.4 but since its 8 pin it may just work fine without messing with the wiring as long as u have the harness
Old 04-04-2011, 01:02 AM
  #59
HunterKiller89's Avatar
it requires a re-pin. the wires that need to be swapped are in my how-to
Old 04-04-2011, 01:10 AM
  #60
yeah that is wrong. Don't go saying things that you don't have a clue about. The LSJ throttle body requires a repin regardless of what motor you put it on.
Old 04-04-2011, 01:12 AM
  #61
then y ask the stupid ? if u already new
Old 04-04-2011, 01:14 AM
  #62
Mr.N00bLaR's Avatar
10-24-2010, 11:48 PM was when he posted the question, I believe he found out since then. Good that it came up though, someone will search on the subject and get this...I hope.
Old 04-04-2011, 01:15 AM
  #63
oh well no wonder. my bad . and idk why i didnt no that for sure since i have all the info saved
Old 04-04-2011, 01:31 AM
  #64
What nooblar said.
Old 04-04-2011, 08:05 PM
  #65
conerboner's Avatar
whoah didn't know my build thread was in here. thanks for posting that up!
Old 05-15-2011, 05:15 PM
  #66
Raiden8816's Avatar
I suppose you can add me to the list as well. I will be updating my thread with more pics and a few vids
Old 05-23-2011, 12:39 AM
  #67
Mr.N00bLaR's Avatar
First post can't be updated but here it is!
Raiden8816's build thread: https://www.cobaltss.net/forums/2-2l...-build-250749/
Old 12-18-2011, 05:09 PM
  #68
Mr.N00bLaR's Avatar
Been a while since I have updated this...:
murdy81's thread: https://www.cobaltss.net/forums/2-2l...thread-265328/
cisco123's thread: https://www.cobaltss.net/forums/2-2l...67/index2.html
drumrush's thread: https://www.cobaltss.net/forums/2-2l...thread-264976/
07cobaltguy's re-rebuild thread: https://www.cobaltss.net/forums/2-2l...thread-265803/
Can't remember if I posted this about the engine moun issue on older cobalts: https://www.cobaltss.net/forums/2-2l...mounts-126651/
And just for a little bit of trolling, the answer was boost: https://www.cobaltss.net/forums/2-2l...uction-265340/
Old 02-23-2012, 09:07 AM
  #69
Axelthered05's Avatar
just found this L61 to LSJ tb adaptor Throttle Body Adapter -- Katech Performance Online Store
05-28-2022 03:47 AM
06MetallicBalt
08-17-2021 03:40 PM
hacadacalopolis
10-28-2015 06:09 PM
riceburner
10-02-2015 05:47 PM
09-26-2015 06:44 PM
Quick Reply: L61/LAP Turbo/Super (Forced Induction) Build Thread
