Lnf turbo manifold on l61
Old 03-09-2017, 10:25 AM
L61durb's Avatar
Does anyone know if the lnf turbo manifold is useable on a l61? Any modification needed?
Old 03-09-2017, 10:51 AM
serious modification is needed and it doesn't really work all that well. The SAAB LK9 intake manifold will work better with less modification.
Also the stock intake manifold seems to work fine for most guys as long as you don't plan on running extremely high boost pressures.
Old 03-09-2017, 11:07 AM
L61durb's Avatar
Can the k04 be used with this saab manifold?
Old 03-09-2017, 11:18 AM
Sorry I was for some reason thinking the intake manifold. The exhaust manifold should work without issue, other than needing the LNF's crossover coolant pipe.
Old 03-09-2017, 11:48 AM
Yes it fits, but i would recommend the sce copper exhaust gasket. And you need the lnf coolant pipe/tstat housing.
Old 03-16-2017, 04:56 PM
08_Slowbalt's Avatar
does anyone know what flange the LNF turbo uses?
Old 03-16-2017, 05:00 PM
A proprietary gm flange
08_Slowbalt (03-16-2017)
Old 03-16-2017, 05:03 PM
Thanks. I was afraid of that.
