M62's turbo build
Old 08-27-2014, 10:30 PM
M62
M62's Avatar
Canada M62's turbo build
M62's L61 build Thread
I've been doing this build for two years down time, saving every penny I could and figured im close enough to the finish line where I can start posting photos and asking important questions with the community here.
I live in Grand Forks, British Columbia, Canada And am Always looking for any fellow modded Cobalt's in the BC Kelowna/Vernon Area to get in touch with for a cobalt cruise.
So Everything I've bought Goes as follows:
Engine:
Wiseco 8.5:1 Forged Pistons .20
Eagle connecting rods
Comp cams stage 2 turbo street/strip camshafts
(Forget exact specs)
Supertech 94" valve springs
Supertech retainers seals etc.
Supertech O/S valves exhaust/Intake
Ported/Machined head
New rocker arms etc..
Crankshaft serviced/Balanced
New Timing chain,Waterpump etc..
(Completely rebuilt everything)
Transmission:
Stage 4+ Excedy clutch 6 puck
Excedy TOB
Quife LSD
ZZP STG 2 Axles
Bolt Ons:
Hahn Turbo Stage IV kit
ZZP 3" exhaust No resonator
ZZP S3 Heat Exchanger
GM IC pump with bracket
Chinese ebay POS Water to air IC
Scrapyard POS Oil cooler
ZZP Triple pillar pod
80# Injectors - (Selling old 60#'s pm if interested/live in canada)
LSJ Throttle Body
ZZP 8pin to 8pin TB Harness
Photos:
The nice S20G sleeping on the back.
What it looks like as a system, I couldn't find a single picture like this for the hahn kit.
The pretty intake manifold with LSJ Throttlebody
Crappy photo of the s20g
s20g sort of all hooked upish
Time Frame:
Estimated to be completed around late September to early November just in time for some
ridiculous snow that I have to park my car for, Hopefully it won't snow by then when im completed i will be uploading lots of video's/photo's since im sure lots of people are curious on which kind's of setups sound/perform good.
First start video:
Exhaust Video:
To buy list:
Tune by trifecta
Meth injection kit
Wideband guages/boost etc
SSBC front and rear brakes
Coil overs (Any Recommendations/Pics?)
AIB Sway bar kit
ZZP motor mount
Halo projector lights/Retro's If anyone has any for sale?
2005/06 Speedometer Km/h
Short Shifter (Any recommendations/pics?)
ZZP Control arms
Am I forgetting anything?
Old 08-27-2014, 10:39 PM
tuned08ss's Avatar
Why trifecta tune?
Old 08-27-2014, 10:47 PM
M62
M62's Avatar
I was going under the assumption it's the only way to tune my car/ Best way to. Am I wrong?
Old 08-27-2014, 11:33 PM
KMO43's Avatar
I live in Calgary but am from Kelowna so I got there often next time I'm there if you're around we could go for a cruise.
I heard there were problems running such stiff valvesprings I would go with Supertech 78# or ZZPs. The 94# are rough on the timing chain
Old 08-28-2014, 12:54 AM
M62
M62's Avatar
Sounds like a plan dude, The motor is already built so I can't my really change it now
Old 08-28-2014, 06:33 AM
joshcsepegi's Avatar
Why are you still using the heat exchanger? I don't see any water to air intercooler in your system.
Old 08-28-2014, 07:13 AM
SR Tech's Avatar
Ditch those worm clamps on the charge pipes and get tbolts or you'll pop couplers off every boost hit
Old 08-28-2014, 08:26 AM
blueLNFftw's Avatar
Why the heat exchanger?
Old 09-05-2014, 11:54 PM
M62
M62's Avatar
i have water air intake; air/air intercooling might be unnecessary but i wanna keep it cold.
Old 10-16-2014, 01:23 AM
M62
M62's Avatar
So the car is up and running, Everything is fine except for a high idle which im assuming is the IAC.When i put the car quickly under drivetrain load it bogs down And i put it back into neutral.Somehow this makes it idle normally?! When i shift into neutral moving the rpm's shoot up until i put it under load again any thoughts or suggestions?
Old 10-16-2014, 08:21 AM
sandman's Avatar
what rpms is it idling at?
Old 10-18-2014, 12:11 PM
06_ion2's Avatar
Awesome! I have almost this same build. But I have a s256 zzp, Vulcan manifold, 2.4tb and patriot head. Just be easy on the trans and don't agressively shift. Oh, and enjoy being fast!
I have a ion and the b&g coilovers from back when they came out as my cars a bit outdated now. You will need Coilovers to hook well. Make the back stiff and try to make the front lower so more weight is on the front. I can hook 20psi on a 235 tire but after that it don't hook amazing. Not a rolling smoke show though.
Old 10-20-2014, 12:25 AM
M62
M62's Avatar
I guess my computer managed to relearn its own idle after driving it for about 50km's.It idles around 875rpm- 900rpm and the revs fall down normally when shifting.Now for tuning Im not sure what site im supposted to buy a Trifecta Tune from?! there's like three of them and they all have different pricing on each of the sites.Can anyone tell me which site i should buy the cable and tune from?! Im running stock injectors right now and want to run my 80#'s but obviously i blow black smoke without a tune.
Old 10-20-2014, 12:33 AM
M62
M62's Avatar
Here's a pic of my engine bay a day before installing the engine
Video's and such will be uploaded when im not feeling lazy..
Old 10-23-2014, 05:14 PM
BlackielawlessSS's Avatar
Nice looks clean!
Old 10-25-2014, 01:11 AM
M62
M62's Avatar
So When I unplug my map sensor i can boost all I want.With it plugged in i can go to 3k rpms which is when my turbo spools before hitting limp mode.I took off my muffler and i can boost on/off with the map sensor plugged in.Just trying to figure out what's exactly causing limp mode before i buy a tune, I know its a stupid idea to run without a map sensor because the input stays at 10kpa.Will a Trifecta tune sort this out or do i need to buy a 3bar map sensor or something?!
Old 10-25-2014, 01:13 AM
M62
M62's Avatar
and i spin the stage 4 clutch like nothing... is there a higher ft/lb torque clutch I can get for the f23? I thought i bought it...
Old 10-25-2014, 11:10 AM
sandman's Avatar
What tune are you attempting to drive it on right now?
and what is the clutch rated at?
Old 10-28-2014, 10:38 PM
M62
M62's Avatar
Stock pcm, 380lb/ft.Obviously im gonna have to pull the tranny and put a stage 5 which ottp sells apparently.. I couldn't find one anywhere.My pressure plate feels too nice though.. Makes me wonder if something else is up.
Old 10-28-2014, 10:40 PM
M62
M62's Avatar
Surprisingly, The stock computer is really capable of learning and adapting to all the **** i've changed on it.IT ran with 60#'s almost fine at idle when the computer was fresh but it was black smoke obviously.I tried putting the 60#'s back in after the computer relarned the idle control n such but it wouldn't run long enough to even get my foot off the gas pedal haha
Old 10-28-2014, 11:03 PM
sandman's Avatar
all that limp mode and stuff will be fixed with trifecta tune. You can stay with stock map just let them know lol.
Old 10-28-2014, 11:43 PM
26gen4's Avatar
Exactly, when i put a TVS on my LE5 i had limp mode. Vince had to fix it, i'd go with a tuner who uses HPT and is hands on. **** the remote tune ****
Also i'd get rid of the breather, your pulling in un metered air
Old 10-30-2014, 01:21 AM
andrewcarr1993's Avatar
Turbo Tech Racing, KY stage 3 or 4 if you want to go all out, should hold 400 ft lbs then the stage 4 you won't get to slip.
Even with a built engine I'd be too worried to run it untuned.
As for the HPT comment, he can't get it, HPT didn't unlock this computer only Trifecta.
Old 10-30-2014, 06:12 PM
26gen4's Avatar
I was in the same boat then E37 beta came out, I believe its supports the 2.2 along with my 2.4 LE5 2008...
Old 10-30-2014, 06:14 PM
26gen4's Avatar
The e37 covers a ton of applications
2007-2010 Silverado/Sierra 4.3
2007-2010 Express & Savana van 4.3
2007?-2010 Cobalt 2.2
2008? Cobalt 2.4
2008-2010 HHR 2.4
2008-2010 HHR 2.2
G5 2.4's
G6 2.4's
Several Buick models
etc.
E37 Tuning
Quick Reply: M62's turbo build
