oil pan replacement
Old 12-27-2007, 11:20 AM
kungfoojesus's Avatar
oil pan replacement
Hi, my brother drove his cobalt LT off the road the other night in thick fog and managed to crack his oil pan with very minor impact. Are these aluminum? He barely hit the dang thing.
Does anyone know where I can purchase a new pan? I'm guessing with all the modifications you guys do around here to suspension that they're a pretty hot item. The stealership wants $160 just for the part. I'm guessing some after market company ya'll love and worship sells this item for much less?
Does anyone make a steel/aluminum hybrid or all steel engine oil pan for these cars?
Thank you for all your help. He delivers pizza and the sooner we can get his car back on the road the sooner he can have some cash flow again.
Old 12-27-2007, 11:24 AM
D4u2s0t's Avatar
i would check gmpartsdirect.com they have oem parts for much cheaper than you would get from any dealer. let me take a look for you.
Kaisoboy's Avatar
Your best bet would be the dealership or do like D4 mentions above. An after market pan will probably be more expensive. That is the type of part that if some one was to make one it would probably be for performance more than just replacement. (e. deeper pan, more volume for oil, bigger oil pump and sump.)
cheers
Old 12-27-2007, 11:25 AM
rnjmur's Avatar
As far as I know there aren't any aftermarket oil pans. The oil pan is pretty easy to replace, maybe an hour tops.
Old 12-27-2007, 11:26 AM
css9450's Avatar
Yes they're aluminum. You'll probably just have to bite the bullet and get a new one from the dealer; I'm not aware of any aftermarket ones and if there were, they'd be deep sump racing pans for big money.
EDIT - Four replies in one minute !!
Old 12-27-2007, 11:28 AM
D4u2s0t's Avatar
here ya go, 97 dollars on gmpartsdirect
http://www.gmpartsdirect.com/catalog/frameset.cfm
that link may not bring you to the product. just put in the year, make & model, and it will bring you to the catalog. in the Search field put in "oil pan" and it will come up.
Old 12-27-2007, 11:48 AM
Thank you guys so much for the help. I appreciate you offering time and assistance especially D4! You guys are so helpful. A lot better than my car of choice forum (euro snobs <sigh>).
The GM direct part is about half the cost! Only problem now is I don't have the part # and they list three oil pans. Do all the motors use the same pan? Their unofficial catalog suggests this but doesn't have any part #'s to back it up. They're all listed as working but I was reading the 2.4 uses different pan from the 2.2 and 2.0. I could use some help on this one.
The dealership was nice enough to give me the part # for what I need. It is part # 12601240 quoted directly from the parts guy.
Does this pan have a gasket like most? I was reading it doesn't.
Old 12-27-2007, 01:00 PM
Kaisoboy's Avatar
Here are the torque specs and removal and install instructions
cheers
Sorry for the second page being upside down. I tried to get it the right way but for some reason it wont.
Old 12-27-2007, 01:45 PM
Wow this is great! You guys are incredible. I'm inspired by your generosity. I'll do a full write up with pictures and post it in the DIY section.
I really appreciate all this help.
Old 12-27-2007, 01:49 PM
mike25's Avatar
cheers
what book did you get that out of?
Old 12-27-2007, 01:56 PM
redlineblueline's Avatar
chilton or haynes has a book for the balt out now
Old 12-27-2007, 02:09 PM
Red07SSNA's Avatar
I ran PN 12601240 in my GM database and couldn't find it listed. Here are the oil pan part numbers my GM database shows for the Cobalt engines:
2.2 Oil Pan PN 12578193 (05-08)
2.4 Oil Pan PN 12578193 (06-08) Shows same as 2.2
2.0 Oil Pan PN 55558816 (05-07)
The factory service manual says to use GM sealant PN 12378521 and lay a 3.5mm bead around the perimeter of the oil pan and oil suction port opening.
Old 12-27-2007, 02:10 PM
Kaisoboy's Avatar
Got it out of my Haynes manual for Chevy cobalt & G5 05-07 repair manual.
cheers
Old 12-28-2007, 08:48 AM
Cobalter LS,
I looked up 12601240 part # and it brought up the oil pan for me on gmpartsdirect.com. I hope I ordered the right one! This # came directly from the dealership parts guy. Hopefully he wasn't screwing with me! The fact that it came up on gmpartsdirect under that number is encouraging to me though.
If all three pans are the same, I just spent an extra $13 on nothing other than a part # difference. The website gmpartsdirect.com listed all three pans for the 2.2 also though. I should have just bought the $87 pan! Oh well no biggie. I searched your numbers and the pan came up too. God if that dealership gave me the wrong pan/pan#... grrr. Hopefully I'll be suprised by a new new STEEL pan when it gets here!!! Hah, I can always dream can't I?
Last edited by kungfoojesus; 12-28-2007 at 08:56 AM. Reason: Automerged Doublepost
Old 12-28-2007, 09:02 AM
D4u2s0t's Avatar
Originally Posted by kungfoojesus
Cobalter LS,
this is out of my area of expertise, so don't hold me to this, but the 2.0 pan may be bigger than the 2.2 pan. it holds about a quart and a half more oil.
Old 12-28-2007, 09:14 AM
Red07SSNA's Avatar
Cobalter LS,
12601240 is probably an older number that has been replaced with the new number. Keep us in the loop and let us know how everthing turns out. Thanks.
Old 12-28-2007, 09:34 AM
css9450's Avatar
I'm pleased to see this is a very easy swap. Some cars require the engine to be raised or pulled to replace the oil pan.
Old 12-28-2007, 02:03 PM
I believe the motor mount must be unhooked. It probably only needs to be supported since its a lower, not an upper mount. Typically motors are balanced on the upper mounts and the lower is just for forward/backward forces, for lack of a better term. Will let you know after I finish.
Old 01-14-2009, 01:13 PM
mike25's Avatar
i hope it is easy and quick..i just ordered an oil pan to take to the garage and have put on.
Old 01-14-2009, 02:41 PM
umrdyldo's Avatar
way to revive an old thread.
Not sure if anyone has a how to on this.
Old 01-15-2009, 09:54 AM
mike25's Avatar
haha i know right? thats what i thought...but owell needed the part number and figured somebody else may be able to use it...besides, this sections a bit dead anyways
Old 01-15-2009, 03:12 PM
06cobaltindallas's Avatar
well this is the only aftermarket oil pan that ive ran across for the ecotec but its for a dry sump system. its on the 1400hp drag car gm uses
http://www.drysump.com/pan26.htm
Old 01-16-2009, 03:49 PM
umrdyldo's Avatar
So for oil pan replacement do you drain the oil, remove bolts. Apply sealant and reinstall or is there removal of other parts to get to the bolts?
Old 01-16-2009, 11:05 PM
HunterKiller89's Avatar
just the bolts...but some of the bolts are a royal PITA. theres a couple that are directly above the sub frame, so theres no way to get a socket wrench in there....i dont remember how i got it off...i think i had to jack the engine up a little. It was abut half a year ago now, but it didnt involve removal of anything else that i can recall.
removing your fender wells helps a lot too, or just un-bolt some of the bolts and peel it back
Old 01-16-2009, 11:11 PM
Jn2
Jn2's Avatar
A replacement cost 110 from gmpartsdirect.com...WTF this is a old thread
Quick Reply: oil pan replacement
