The Phoenix Rises Once More
Old 08-12-2016, 09:41 PM
Foximus's Avatar
So, those of you that know me, or at least know of me, know that I am not normal. Hell I probably have something super wrong with my head, after all I've built what I think is the only Cobalt Time Attack car that wasn't handled by John Powell. We have built a team, and have some awesome sponsors that help us out, to build and prove that the Cobalt can and will hold its own vs the Honda Time Attack Fleet in the USA.
Lets go into a little back story on this car.
Purchased Sept 2005. So fresh, so clean.
Engine #1 (Stock L61) Let go back in 2009 with a spun crank bearing at 120,000 miles.
Engine #2 (Junkyard L61) Lasted 14,000 miles before it got more rod knock than.... well, lets just say running 90w in the crank case wouldn't quiet it down.....
Engine #3..... A very nice fully built L61 I picked up off a member on here when I was still in Pittsburgh. It was built for a turbo, and for 2 years I ran it NA (and was sad) Then put a blower on it. Trifecta was super awesome and Steve did a lot of work with us when I moved to SoCal to get us better for Time Attack. But with around 60k on the motor, we did this. and blew a hole thru cylinder #1. I think we had hurt the motor at Super Lap in 2015, but then we went SUPER LEAN at GTA Rd 1 this year and yeah... Melt.
So now......
(DEI makes some AWESOME heat shield)
The Phoenix will be rising again soon, and this build will be absolutely nuts. Doing a few of those "You shouldn't try this, it will be too hard / too much work" and some ridiculous upgrades are coming..... I will be using this thread to tease and post things as we are now getting closer to the motor coming back together......
The following 2 users liked this post by Foximus:
jdbaugh1 (08-13-2016), Snail_SS (08-13-2016)
Old 08-12-2016, 10:59 PM
Sub'd for updates. Got any more info on the DEI heatshield stuff?
Old 08-12-2016, 11:35 PM
le5 time
Old 08-13-2016, 12:03 AM
Foximus's Avatar
We run the DEI Titanium Wrap on our long tube and downpipe, its held up amazing well even with getting splashed and whatnot. This is the "DEI Floor and Tunnel Shield 2" its about 1/8" thick, adhesive backed. Super easy to cut with good scissors. We made one big piece for the exhaust tunnel, and then cut and pieced together the firewall so its super neat, and covered the seams with their heat tape.
le5 time
Nah. Remember that thing I asked about a few months ago that y'all said would be crazy and take too much work to do........
Old 08-13-2016, 12:15 AM
lsj head swap?
Old 08-13-2016, 12:26 PM
Foximus's Avatar
lsj head swap?
Yup. L61 Bottom End, LSJ Head, bunch of custom / R&D internals......
Old 08-13-2016, 02:04 PM
Subd for updates
Old 08-16-2016, 10:03 PM
Foximus's Avatar
So, while we wait for the Custom Arias pistons to come in, heres another shot of the block getting ready:
Out with the old, stock sleeves....
Stock L61 Sleeves
And in with some tasty Powerbore Ductile Iron Sleeves
New Powerbore Sleeves
Old 08-17-2016, 09:15 AM
jdbaugh1's Avatar
What all does it take to swap out sleeves?
Old 08-17-2016, 10:45 AM
user 72239's Avatar
holy ****. I've never seen a set of JE pistons with a hole like that in them. you must have gotten that bad boy HOT lol
user 72239's Avatar
Going 2618 Arias or 4032?
Old 08-17-2016, 11:17 AM
royce777's Avatar
I still run that sway bar I bought off you like 6 years ago
Old 08-17-2016, 01:38 PM
Foximus's Avatar
Neither. These are 1 off custom's they are machining for us.
Old 08-17-2016, 08:33 PM
Foximus's Avatar
They press out fairly easily I am told.
Old 08-18-2016, 09:26 AM
there is a gm service tool to replace them
Old 08-18-2016, 09:27 AM
they are most likely made of one of those two alloys
user 72239 (08-18-2016)
Old 08-19-2016, 12:18 PM
Foximus's Avatar
So..... Trevor sent these shots the other day as well.
Should work nicely for a heat exchanger.
Old 08-19-2016, 12:35 PM
jdbaugh1's Avatar
That thing's a beast. With this size of heat exchanger I have always wondered at what capacity does it start not really making a significant difference based on the heat transfer limitations of the stock IM cores. I'd be curious to compare exiting water temps of different heat exchangers.
Old 08-20-2016, 04:20 PM
I love the car and what youve done with it. good luck
Old 08-20-2016, 05:24 PM
Foximus's Avatar
Best birthday present I coulda ever bought myself.
Old 08-30-2016, 06:49 PM
Tjolley's Avatar
Pistons come in Wednesday. Ill be picking up the car this weekend to start all the fab. lots to do so I cleared out all the projects I have to make room for this one car. other than some little BS things ill have everything to get the car running. Goal here is to gain 80-100 HP at the same boost level. car will definitely rip. After wat I learned from steves car with raised compression and the HEs I have been building this should easily make 320 ish HP with around 10 PSI of boost.
Old 08-30-2016, 06:51 PM
Tjolley's Avatar
oh and once I get the car to my place there will be lost of pics so don't worry Foximous will have lots to post very soon.
Old 08-31-2016, 06:49 PM
WVU_SS's Avatar
Very cool man. Sub'd for more
Old 08-31-2016, 10:14 PM
63 Nova SS's Avatar
Nice, make it happen.
Old 09-05-2016, 08:59 AM
jdbaugh1's Avatar
What compression ratio are you guys aiming for?
Quick Reply: The Phoenix Rises Once More
