Possible build? 90 psi 2.2 ecotec?
Old 08-18-2015, 11:59 AM
Justin12345's Avatar
So I'm curious to all the l61 owners I'm thinking about starting a build is there anyway to build an engine with 90 pounds of boost. My guess probably not. If I did build this what parts should I be looking for to handle 90 psi of boost. Plan:
Engine bored 30 over bore.
Eagle rods and bearings
Wiseco pistons 8:1 compression (drop in compression)
Billet crankshaft 4340
Supertech ported valves
82lb springs and retainers
Valve seals (no idea yet)
Competition camshafts (strip cams or racing cams) not fully decided.
Now would I need to have a Darton sleeves installed. What should I be looking for to push 90psi. (Actual psi 80) but 10 just in case anything goes bad. Will I have to nitro it, or could I use high octane gas. 97+?
Any info would be great considering I'm starting this ridiculous build soon.
Justin12345 is offline
Old 08-18-2015, 12:36 PM
Slobodan Milošević
07blackg5's Avatar
07blackg5 is offline
Old 08-18-2015, 12:57 PM
exninja's Avatar
This can't be real.
exninja is offline
Old 08-18-2015, 01:22 PM
Haven07's Avatar
....lol
Haven07 is offline
Old 08-18-2015, 01:25 PM
Originally Posted by exninja
This can't be real.
qfe gotta be a troll
ECaulk is offline
Old 08-18-2015, 01:53 PM
no_ss's Avatar
3 256et on an aggressive tune? Lmao
no_ss is offline
Old 08-18-2015, 01:56 PM
Haven07's Avatar
Don't forget unicorn ****. The ultimate cooling mod! Good luck find long one though
Haven07 is offline
Old 08-18-2015, 01:59 PM
Okay maybe I wasn't specific enough I'm running the super at 20 psi and the turbo at 30psi... What's the absolute pressure I figured it out last night it's was 5.4 absolute pressure to psi was like 78 psi of boost... Judging by the mathematics... So seriously how do I get the car to take 78 - 80 psi of boost... I'm highly thinking of darton sleeves anyone have another idea...
And stop twacken yourselves this is literally my first forum. Me and 3 other are helping with the build and I got a rough idea what im getting into. And seriously if you can have a 2000hp vw golf, 4 cylinder I'm pretty sure an ecotec has the same technology around.
Stop your cursing if you have nothing good to say please knock it off go troll someone else stupid forum about ricing there cobalts, sunfire, cavalier.
Old 08-18-2015, 02:02 PM
Dipped_Cobalt's Avatar
why not just give more details...
Dipped_Cobalt is offline
30 as in 30 thousands of an inch
Old 08-18-2015, 02:06 PM
double clutch's Avatar
No one twincharges anymore because of all the issues and a bigger turbo will be more efficient and supply more power. Save yourself a headache.
double clutch is offline
Old 08-18-2015, 02:19 PM
Haven07's Avatar
If your serious about this look at the 1400 ecotec dragsters as well as a couple if the engine build threads. Highly recommending looking at mr.b's stickied thread about the design of our cylinder heads and it's limitations since it appears that our heads are the limiting factors of our engines.
A twin charge set up won't be needed and may cause a lot more issues than it's worth
Haven07 is offline
Old 08-18-2015, 03:29 PM
You'll most likely lift the head. Also that blower will become a restriction. Most likely need a compound turbo setup and deep pockets to get 2000hp.
I'd also like to see some proof of said 2000hp 4cyl VW, I know some evo guys can push over 1200 on custom turbos with the 4g63 block
ECaulk is offline
Old 08-18-2015, 03:33 PM
turboecotec02's Avatar
I say this is for laughs still
turboecotec02 is offline
Old 08-18-2015, 04:08 PM
blueLNFftw's Avatar
FMSR is what you need.
blueLNFftw is offline
The following 5 users liked this post by blueLNFftw:
07blackg5 (08-18-2015), ECaulk (08-18-2015), hawkssoccer11 (08-19-2015), Jesse (08-18-2015), sandman (08-18-2015)
Old 08-18-2015, 04:21 PM
Car throttle has an issue top 10 super sleepers. That's were I seen the vw. YouTube or Google it it should still be around. And yes I've seen that badass fmsr head... But I'm worried why are they the only ones that can make a head that pushes 60 psi + ....
Now someone please tell me I got my number wrong but if my blower is going at 20psi and my turbos kicken in 30 I don't actually get 78psi do I?
Old 08-18-2015, 04:22 PM
blueLNFftw's Avatar
20 + 30 = 78.
Obviously.
Old 08-18-2015, 04:23 PM
Oh and I'm sticking with twin, super hard tune. But frankly I don't care, I just hate hate hate turbo lag.. The bigger the turbo the worst the lag.
Old 08-18-2015, 04:25 PM
Originally Posted by blueLNFftw
20 + 30 = 78.
Obviously.
Actually if you look at the mathematics (there's a thread on here you actually can't just add them together.... ) when I have a desktop in front of me I'll quote the link to it.
Actually here's the thread https://www.cobaltss.net/forums/adva...ormula-132146/
Old 08-18-2015, 04:27 PM
Haven07's Avatar
Lol fmsr
Also, nitrous can be used to spin a big turbo faster just saying
Haven07 is offline
Old 08-18-2015, 04:31 PM
No, now that would be ridiculous. Nosing it every time I give it gas...
Old 08-18-2015, 04:38 PM
What is your hp and tq goals realistically? I dont think you realize what 2,000hp in a 3,000lb car feels like.
Old 08-18-2015, 04:55 PM
Devin86's Avatar
Stage 10 should do it bahaha
Devin86 is offline
Old 08-18-2015, 05:17 PM
If you build a 2000hp car you will not be daily driving it. Also can't find that article about a 2000hp VW, found the 1100hp Golf that does 0-155 in 6.17seconds and was built by a race team. Thats the kind of engineering you're going to need and full access to a very complex tuning system, also that Golf used a specialized turbo and AWD to plant the power.
Once you hit the 350whp/350wtq number in these fwd cars you're fighting for traction in a gear below 3rd (those in the 500 category have issues in 3rd), you go to 2000hp you will be looking at a completely custom front end to handle the correct width tire to put the power down.
ECaulk is offline
Old 08-18-2015, 05:41 PM
exninja's Avatar
I like how you start by asking how to put 90psi into the engine but then say that constant "nos" is ridiculous.
Even if you were able to get all of that power out of the engine, why bother? You'll end up with a really expensive smoke machine. Every bit of the drivetrain would have to be replaced. Totally new fueling system. Etc. Etc. There are much better ways to spend your money.
BTW, FMSR is a joke. Literally.
exninja is offline
Quick Reply: Possible build? 90 psi 2.2 ecotec?
