Ok so my car has 101,392 Kms on it. What kind of Maintenance should I peform if any?
The car has now over 100,000 Kms on her and still running strong.
Does anyone (HALF-CENT) have any recommendations for service at this point?
Anything I need to chance/replace/refill?
Any advice would be great!
P.S. I personally think Different type of oil like that are just cash grabs IMO.
63,000 Miles+ or so.
^^^this guy FTW
I put 35k miles on my car in my first year of having it. Damn delivery job Oh yea and there was a trip from Texas to PA in there as well so that didnt help.
2 months shy from owning the balt a yr, only put 78xx or 79xx on here. 2 oil changes is all I've done! My tires are good, no need for a rotation, maybe at 15,000. I thought I drove a lot..............wait...................it's winter!!!!! Summer will changed all that! lol
Hey Neil,
Oil change-obvious
drive belt
air filter
tranny service*
Also a good time to check brakes (caliper service) and check rear adjustment.
I think GM claims plugs last 160,000km but a good time to crack them loose (avoid seizing)
and do a quick plug check.
Good luck
Steve.
Oil change-obvious
drive belt
air filter
tranny service*
Good luck
Steve.
I'd go ahead and replace the plugs anyway; they aren't expensive. I like to flush the coolant early too, but your car is at most 2 years old so you could probably wait on that. Your call.
Hey Neil,
Oil change-obvious
drive belt
air filter
tranny service*
Good luck
Steve.
Oil change-obvious
drive belt
air filter
tranny service*
Good luck
Steve.
Thank you for the advice.
I've done the oil change. Check.
Had my tranny fluid changed already at 50,000 kms so I'm not sure if I need to or not but it's a great idea. Maybe.
Drive Belt. Not done yet, great idea. Will do.
Air Filter. Will do.
Brakes. Can't afford yet. Will do when can afford.
Spark Plugs. Already changed at 78,000. Check.
Thanks again Steve.
It's about time someone just gave me a straight up answer.
man just do a full tune up like back in the day, thats what i'll do when i hit 100,000km,
oil, intake filter, gas filter, spark plugs, some lube, coolant. doubt you need anything else,
