Removing Seatbelts - Cobalt SS Network
Technical Discussions ONLY!
Thread Tools Search this Thread
Old 02-27-2007, 06:59 PM   #1
NP05Cobalt's Avatar
Images: 3
Removing Seatbelts
Okay how do you remove the seats belts for the driver and passenger seat? i know the two little bolts in the side panel removed but then what? any input will help
NP05Cobalt is offline   Reply With Quote
Old 02-27-2007, 07:02 PM   #2
chipsgt's Avatar
Images: 8
Installing a harness?
chipsgt is offline   Reply With Quote
Old 02-27-2007, 07:05 PM   #3
do yall know if racing seat belts will void the warrenty?
stvn is offline   Reply With Quote
Old 02-27-2007, 07:06 PM   #4
chipsgt's Avatar
Images: 8
Quote:
Yeah, the warranty on your seat belts...
Old 02-27-2007, 07:48 PM   #5
Quote:
what about if you keep the stock seat belts but just add racing ones too.
Old 02-27-2007, 08:23 PM   #6
NP05Cobalt's Avatar
Images: 3
yahh im adding in harnesses...already have the racing seats in and want the stocks out... anyone tell me how?
Old 02-27-2007, 08:30 PM   #7
Images: 6
There's a how to posted on installing a harness and I believe it shows how to remove the stockers.
Before somebody comes and says "use the search button" here is the link:
Schroth Rallye 4 Harness install
RJSS is offline   Reply With Quote
Old 02-27-2007, 08:47 PM   #8
chipsgt's Avatar
Images: 8
Pretty much anything you do to the car, that removes or in someway compromises factory parts, you will loose the warranty on those parts.
You can not however loose any other part of your warranty based on that.
Old 02-27-2007, 08:51 PM   #9
Images: 8
definetely take pics of the seats in the car.
Listerman is offline   Reply With Quote
Old 02-28-2007, 10:22 AM   #10
NP05Cobalt's Avatar
Images: 3
i have pics of the seats if you look at my pics
Old 02-28-2007, 06:16 PM   #11
NP05Cobalt's Avatar
Images: 3
okay well i finally broke loose the bottom bolts after 5 minutes of trying...but now i am about to strip out the top bolts cauz torqs suck... anyone have any ideas of what i can do before they are stripped? please let me know asap
Old 02-28-2007, 06:20 PM   #12
South Central *********
Images: 982
use a hex socket if torx are twisting off
JapEatr is offline   Reply With Quote
Old 02-28-2007, 06:26 PM   #13
NP05Cobalt's Avatar
Images: 3
but would a hex fit even though there are half the teeth?
Thread Thread Starter Forum Replies Last Post
Wiseco Piston install quick question Turbo Johnny 2.0L LNF Performance Tech 13 08-08-2016 03:29 AM
Extreme Dimensions is now hiring! Extreme Dimensions South Pacific 0 09-24-2015 06:24 PM
Help Need To Remove Factory Heat Exchanger katahdin_lubricants General Cobalt 3 09-20-2015 08:24 PM
Swirls won't come out after buffing. brickloaf Show & Shine 50 09-18-2015 09:28 PM
Porcelain piece broke off a spark plug and fell in the cylinder; LNF running weird Getaway_Driver Problems/Service/Maintenance 41 09-08-2015 10:41 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
