Removing Seatbelts
Removing Seatbelts
Okay how do you remove the seats belts for the driver and passenger seat? i know the two little bolts in the side panel removed but then what? any input will help
There's a how to posted on installing a harness and I believe it shows how to remove the stockers.
Before somebody comes and says "use the search button" here is the link:
https://www.cobaltss.net/forums/show...racing+harness
Pretty much anything you do to the car, that removes or in someway compromises factory parts, you will loose the warranty on those parts.
You can not however loose any other part of your warranty based on that.
okay well i finally broke loose the bottom bolts after 5 minutes of trying...but now i am about to strip out the top bolts cauz torqs suck... anyone have any ideas of what i can do before they are stripped? please let me know asap
Getaway_Driver
09-08-2015 09:41 AM
