Thewafflesareburnt's Toasty Fresh Build Thread
Old 03-08-2016, 01:30 AM
  #101
thewafflesareburnt's Avatar
Actually the more I think about it the more it sounds like a vacuum leak. I shall adventure more in the morning and tighten many bolts and hoses
Old 03-08-2016, 01:18 PM
  #102
jdbaugh1's Avatar
Do you have a wideband to see where your air/fuel ratio is? One time my MAF sensor wasn't reading right and my air/fuel leaned way out and acted like you are describing.
I have an 06 so I don't know if it is something they changed by 08 but my knock sensor was making my engine pull serious timing robbing ton of power. Didn't make it stutter though.
I also had a vacuum leak the first time I put an SC on. I tracked it down with a can of brake cleaner. I just sprayed it on the outside of suspect spots and you can hear the engine rpm change if you hit a spot with a vacuum leak.
Old 03-08-2016, 01:20 PM
  #103
Slobodan Milošević
07blackg5's Avatar
I second the wideband, if you don't already have one. And some sort of obd2 software that will let you log parameters
Old 03-08-2016, 01:21 PM
  #104
Well after hunting for vacuum leaks all morning I don't have any anymore. The problem persists. I don't have a wideband which I know I really should. It will pull just fine through the rev range at 1/2 to 3/4 throttle it's only when I push it that it lurches and stutters
  #105
I do have an obd thing I can log with though
Old 03-08-2016, 01:23 PM
  #106
Slobodan Milošević
07blackg5's Avatar
is it just a live obd gauge/app type thing, or will it actually record data to analyze later?
  #107
I still feel like it could be fuel related that it's trying to compensate for lower octane
Old 03-08-2016, 01:24 PM
  #108
Just an app I don't think I can save it
Old 03-08-2016, 01:34 PM
  #109
Slobodan Milošević
07blackg5's Avatar
try to find one that records data. you will never be able to watch the app well enough to diagnose anything properly
  #110
Slobodan Milošević
07blackg5's Avatar
what plug gap are you running?
Old 03-08-2016, 02:31 PM
  #111
So it is indeed pulling timing. MAF seems to read correctly. I emailed zzp to see what they think
Old 03-08-2016, 02:36 PM
  #112
Slobodan Milošević
07blackg5's Avatar
does it only happen when you mash the gas, or can you roll into it and replicate the problem?
Old 03-08-2016, 02:38 PM
  #113
I can get past it at 1/2 to 3/4 throttle but it happens whenever I go wot whether mash or rolled into
Old 03-08-2016, 02:39 PM
  #114
Also if I'm going 50-60 in 4th and go wot it's fine. seems to be 1st 2nd and 3rd where the issue lies if that's possible
Old 03-08-2016, 02:47 PM
  #115
Plug gap is .035 sorry didn't see it. But exact same problem with stock plugs and new plugs with smaller gap
Old 03-08-2016, 03:52 PM
  #116
Disconnected batt for 10 min. Problem improved and car does not buck as much but is now more of a loss of power. I will check the injectors for vacuum leaks later
Old 03-08-2016, 04:10 PM
  #117
LsCobalt07's Avatar
Make sure you use dielectric grease or something similar on the o rings of the injectors. Also check the SCIP sensor, I had a vacuum leak there. If you have a boost/vacuum gauge it should be around -18inHg of vacuum at idle and if there is a vacuum leak it may read closer to -10inHg, as it did in my case.
Old 03-08-2016, 04:41 PM
  #118
Didn't help. I did notice the insulator seals have some flat spots that may be causing issues. I'll by some starting fluid and investigate tomorrow. Other than that it has to be in the tune
  #119
My vacuum is -16--17 which is pretty close
Old 03-11-2016, 01:15 AM
  #120
I'm almost at the point of giving up and changing back to n/a. I love the boost and whine, but this is my daily and I don't the time or money to buy a second tune or hptuners. And even if there was someone in the houston area with hptuners they could easily be 2+ hours away and still be "houston area"
Old 03-11-2016, 09:18 AM
  #121
jdbaugh1's Avatar
How did you check for vacuum leaks? I got all my vacuum leaks fixed and I pull about 20 inches of mercury sometimes 21. 16-17 seems a bit low.
With your mix of gas in there, one thing to try might be to add a good name brand of octane booster. Doubt you would be having problems at that low of load with 3.1" on M62 but it could be knocking a bit. Do you know what degree timing your tune commands at WOT? I was around 16.5 with M62 on stock internals. If you are turned up to hot combined with the mix of gas that could be giving you problems. I'm pretty sure our cars have no real way of checking the octane other than the knock sensor.
If you are having misfires your computer should catch it and if you have an OBD you can verify. If you are running lean I think you might be able to take out your spark plugs and they may have a whitish tent to them.
Anyway you could get a video of what it is doing?
Old 03-11-2016, 01:05 PM
  #122
I will get a video today. No misfires and no vacuum leaks I took the whole thing apart and back together yesterday. I will check the timing also. I have also put more premium in the car since the first time because it is absolutely drinking has. I have averaged 16-17 mpg. Thank you for other things to check.
I also found a place in Houston that will dyno tune the car for $600 so that may be an option down the road
Old 03-11-2016, 01:16 PM
  #123
Oh I didnt see you said how did I check for leaks. I sprayed starter fluid
Old 03-11-2016, 01:17 PM
  #124
jdbaugh1's Avatar
Wow with that gas mileage I almost wonder if you're running too rich. If that is the case your spark plugs might be black. Have you noticed any black smoke out of your exhaust? I am averaging 22mpg with TVS 2.9" and 650CC injectors and I have been doing a lot of test pulls.
When you put the intake manifold back on did you use a new gasket? I think they are kind of a "crush" gasket and don't work as well after they have been compressed. If you spray some brake cleaner around the edge of the intake manifold and your idle bogs down (that is where I had a leak the first time because ZZP gave me the damn LNF gasket on accident) that is where the leak is.
I also know that my initial "canned tune" needed a lot of revisions before my car was running right at all. I am assuming that is the option from ZZP as they don't do data logs? So it really could just be your tune.
Old 03-11-2016, 01:19 PM
  #125
Why not just buy hptuners and have someone tune you?
Quick Reply: Thewafflesareburnt's Toasty Fresh Build Thread
