Full service - Cobalt SS Network
2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Technical Discussions ONLY!
LinkBack Thread Tools Search this Thread
Old 01-09-2014, 04:00 PM   #1
Full service
I want to change all my fluids in my car and im hoping someone has a link to the service manual so i can look up what fluids I need to buy.
So far the only thing im sure i'll have to get from the stealership is transmission oil.
09 Cobalt LS XFE 5spd
unijabnx2000 is offline   Reply With Quote
Old 01-11-2014, 03:45 PM   #2
I put in Royal Purple Max ATF for my 09 XFE, F23, apparently they switched to all automatic transmission fluid after a certain year so when building them they only have to use one kind for everything.
As for the other things I'm not sure, there is a how to I found by searching, I believe it was of a different site though.
andrewcarr1993 is offline   Reply With Quote
Old 01-27-2014, 09:15 PM   #3
Images: 1
Any ATF-4 fluid can go into the tranny, as said above they don't use gear oil after I think 2006 or 2007 for convenience. I'm assuming you don't have your owner's manual so I won't suggest looking there for the fluids but you can probably just type in whatever fluid into the search forum thing and it'll bring you to a helpful thread.
LotusRenaultF1 is offline   Reply With Quote
Old 01-27-2014, 09:32 PM   #4
Images: 1
Coolant is Dexcool, Brake fluid is DOT3.
06_cobalt is offline   Reply With Quote
Old 01-27-2014, 09:47 PM   #5
Amsoil atf in my f23. Motor gets amsoil signature 0w30 with their ea filter. Pleased with results so far on 15k change interval. Dexcool for coolant. Dot 4 can be used for brake fluid. Most companies now market brake fluid as dot 3/4 as 3 is becoming obsolete. Higher boiling point, same function.
Xmetalhead2003X is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
LE5 turbo setup patooyee 2.4L LE5 Performance Tech 50 10-15-2015 06:11 PM
anyone have stance coils for sale? OrangeCoba Suspension 1 10-01-2015 11:00 PM
2.0 LSJ Engine: 2006 G85 Red SS, With TVS SSLOW06 Complete Cars 1 10-01-2015 08:21 PM
For Sale 2006 Cobalt LS (SS Upgrades) Car or Partout dieGone Complete Cars 0 10-01-2015 07:27 PM
Wrong Trans installed under warranty? importkiller Problems/Service/Maintenance 11 09-30-2015 08:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
