Full service
Full service
I want to change all my fluids in my car and im hoping someone has a link to the service manual so i can look up what fluids I need to buy.
So far the only thing im sure i'll have to get from the stealership is transmission oil.
09 Cobalt LS XFE 5spd
I put in Royal Purple Max ATF for my 09 XFE, F23, apparently they switched to all automatic transmission fluid after a certain year so when building them they only have to use one kind for everything.
As for the other things I'm not sure, there is a how to I found by searching, I believe it was of a different site though.
Any ATF-4 fluid can go into the tranny, as said above they don't use gear oil after I think 2006 or 2007 for convenience. I'm assuming you don't have your owner's manual so I won't suggest looking there for the fluids but you can probably just type in whatever fluid into the search forum thing and it'll bring you to a helpful thread.
Amsoil atf in my f23. Motor gets amsoil signature 0w30 with their ea filter. Pleased with results so far on 15k change interval. Dexcool for coolant. Dot 4 can be used for brake fluid. Most companies now market brake fluid as dot 3/4 as 3 is becoming obsolete. Higher boiling point, same function.
importkiller
09-30-2015 07:18 PM
