Intake Swaps
Intake Swaps
Hi everyone has been over a year since I have been here. Just pulled the cobalt out for the spring.(I park my car all winter, it's a 2010 2.2l with all the options) I have been looking into some intake upgrades. Now to my understanding a 2.4 intake manifold/MAF Will bolt right up to my motor correct? Basically my car is super slow but i wouldn't mind some easy bolt on upgrades.
keep my MAF? lol do i have an option, due to the fact its regulation air flow. Im just asking if there is a bigger MM MAF then my OEM one currently installed. For example, is a 2.4L MAF bigger than mine? meaning if it is bigger will it allow more airflow, or even a 2.0L SS MAF would be nice too. As long as i could install it and reset my computer and the MAF calibrates ok with my air/fuel ratio. ]
Also, isnt the MAF part of the air box housing? if so how are ppl doing CAI lol
when I had my lap I put the older style 2.4l intake manifold and I noticed I had more top end power and when I swapped the stock manifold back on (09 and up lap and 09 le5 and up share the same manifold) I noticed I had better low end power so if you want better top end for your lap put older style 2.4 manifold on
The amount of air you are flowing I do not believe a bigger MAF will help you.
Most noticeable gains will be from a short ram/true cold air intake (into the fender), and a header/exhaust setup.
Also... FI will be the biggest gain.
ThoR294
10-04-2015 08:44 PM
OrangeCoba
09-25-2015 06:06 PM
