2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
turbo weld on...
Old 08-21-2010, 05:27 AM
Ryancobaltss's Avatar
turbo weld on...
what would be the down side to have a shop weld on a turbo to my stock DP and header?
thanx XD
Old 08-21-2010, 05:36 AM
sundevil07's Avatar
lawl
Old 08-21-2010, 05:57 AM
im going to LAWL if i do it? XD
Old 08-21-2010, 06:01 AM
sundevil07's Avatar
Man just do some research, your stock mani will not support a turbo. Check out zzperformance.com
Old 08-21-2010, 08:48 AM
BlackCobalt707's Avatar
locate yourself a equal length manifold lol.
Old 08-21-2010, 09:07 AM
ecot3c inside's Avatar
guys, he's talking about putting the turbo on his dp... like sts turbos.. I would get a bracket for the turbo welded on so one day it wont just break off or leak. could work..
Old 08-21-2010, 10:07 AM
he said "stock downpipe and header" if you put it on the header might as well get a manifold
Old 08-21-2010, 10:12 AM
Kyle4236's Avatar
if it blows or seizes you're gonna have to spend even more money
Old 08-21-2010, 02:34 PM
Ryan@zzp's Avatar
Thank you
Old 08-21-2010, 05:55 PM
just got the question.. just get a turbo manifold, don't rice that out dude.
Old 08-21-2010, 05:59 PM
ecotecon18s's Avatar
get the manifold, turbo, and get the adapter that Garrett makes to bolt the turbo to the stock dp.
Old 08-21-2010, 06:07 PM
RoadconeTuning's Avatar
do it... it'll work GREAT!
Old 08-21-2010, 06:09 PM
I'm too JDM for you
BLAZIN07SS's Avatar
do it right or don't do it at all. i recommend zzp
Old 08-21-2010, 06:20 PM
BIGGSS_SuperCharged's Avatar
heres a good idea. save your money and get an ss makes alot more sense than trying to make an ls fast...
Old 08-22-2010, 02:04 AM
Nighthawk243's Avatar
Uh... I wouldn't do that. If your turbo ***** out, you're out a manifold too.
Old 08-22-2010, 01:53 PM
please be kidding. i hate when people say this. everyones budget is not the same
Old 08-22-2010, 02:11 PM
07cobaltguy's Avatar
well you can tell that to all the ss/sc's ive **** on in my area
Old 08-22-2010, 06:47 PM
j27-2's Avatar
The best option for you if you must go that rout is to have a shop weld a t3 or whatever flange the turbo requires and bolt the turbo to it. The only problem with this is having clearance to mount the turbo.
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
Tupp
01-02-2016 12:04 PM
hacadacalopolis
10-28-2015 06:09 PM
maliki778
10-01-2015 07:39 PM
Quick Reply: turbo weld on...
