2.4 supercharged guys: few quick questions.
Old 02-11-2014, 12:31 AM
Spawne32's Avatar
Should be easy ones to answer.
1) What size injectors are using for 2.4 M62 supercharged setups with the smallest pulley and additional mods.
2) Where are you getting the injector timing/offset information for non LSJ injectors should you be using a larger then stock injector?
3) How are you changing the MAP sensor from 1bar to 2bar via HPtuners?
4) Are you running entirely MAF or are you tuning with speed density and how are you adding boost columns to the speed density tune via HPtuners? (pics of this would help immensely)
5) How much boost can you expect to see given the various pulley sizes available?
6) Does the 2.4 crank pulley match the same size as the LSJ?
7) What adjustments have you made to the variable valve timing table to account for boost with the supercharger?
Old 02-11-2014, 12:38 AM
ItalianJoe1's Avatar
In for info. I don't have time to post up a lengthy reply tonight from my 2.4 turbo tuning experience but the MAP is on a separate page somewhere, I stayed full MAF tuned, VVT adjustments are basically to eliminate overlap and improve exhaust evacuation. You can advance the exhaust cam a little bit anywhere you would be in boost, gotta play with it and see how your results work out.
Old 02-11-2014, 12:46 AM
Spawne32's Avatar
Well whenever you got time, id love to hear some info regarding the boost tuning with the 2.4 and hptuners, there isnt much info out there with hptuners and the 2.4 motors.
Old 02-11-2014, 12:51 AM
noorj's Avatar
1) Depends on fuel used, even with ethanol 60# should do fine but again depends if you wanna push her
2) 2.2 & 2.4 Fuel Injector Calibrations
3) in HPT engine diagnostics-->airflow-->map sensor linear and map sensor offset
4) MAF tuning maf high and over 4000 Hz ish and you can VE tune under that, it sucks tho. You can purchase a custom OS to VE tune in boost but not worth it IMO
5) boost doesn't really matter dont really worry about it, it will be under 1 bar gage so a 2 bar map will read it fine
6) Not sure
7) as joe said, decrease overlap while keeping advance up down low, retard up top. its alot of playing with tho unless you got cash for lots of steady state dyno time
Old 02-11-2014, 12:54 AM
Spawne32's Avatar
Thanks for the injector cal info, thats exactly what i was looking for. Reason I ask about the pulley vs boost amounts is because I wanted to get an idea of what pulley size to go with or just go for the smallest one. I also wanted to calculate blower speed to make sure im not over revving the blower by much.
Old 02-11-2014, 01:13 AM
noorj's Avatar
just go 2.8, make nice power and won't be just making hot air
Old 02-11-2014, 03:04 PM
Spawne32's Avatar
from what im reading around the boards 2.8 pulleys are about 10-12psi or so?
Old 02-11-2014, 08:23 PM
2.8" should put you closer to 13-14psi, it's good for nearly 18 on a 2.0 car. Keeps the blower from overspinning too much if you aren't revving past 7000 also. I spun my 2.8 setup on my LSJ to 7600 happily for a long time. With my cams and porting work it was only about 15psi peak but with stock manifolds and stuff you will reach nearly 20psi on the smaller displacement at those higher rpms. Still goes way into the excessive heat production part of the curve at that point though. Keep it around stock redline and it will be super happy.
Old 02-11-2014, 08:45 PM
Spawne32's Avatar
most it would ever see is 7k AT MOST, id never spin the auto faster then that anyway. Ill be running a dual pass end plate with the S3 heat exchanger with the option b kit as well. I also have a new torque converter on the way as well to replace the tired GM one. Trans is otherwise in good condition, when I did the fluid flush when I bought the car it looked like it had been regularly serviced and the fluid came out clean and the trans was spotless. The only issue im dealing with now is the supercharger i bought was broken during shipping. I have to take it over to my buddys machine shop and see if he can weld a new piece onto this without warping the rotor bores.
Old 02-12-2014, 12:03 AM
Yeah that sucks. If the welder knows how to properly weld cast aluminum you should be fine. Mild pre-heating and careful weld heat application are key. That's also at the farthest corner of the base so it shouldn't be too bad to heat sink the case while welding.
Old 02-12-2014, 12:11 AM
Spawne32's Avatar
Might just wind up getting a new blower case from zzp if the UPS insurance covers it, rather not risk turning this thing into a brick.
Old 02-13-2014, 09:36 PM
Jacob4ta's Avatar
If ups falls through, you could probably still get something back for your blower. Plus, m62s show up in the classifieds fairly often.
Old 02-13-2014, 09:38 PM
Spawne32's Avatar
I bought it from 07MetallicSC so im confident that hes going to make sure the issue is taken care of one way or another.
Old 02-20-2017, 02:26 PM
Cobalt_noob's Avatar
This is a thread from the dead
Anyways, its important i need to ask.... ZZP on their S/C kits say that, "MAP Sensor notes: '06/07 2.4 comes with a 2 bar MAP, '08-10 2.4L and '07-10 2.2L comes with a 4 bar MAP. Custom PCM programming is required to change the MAP sensor, it is included in our PCM file."
I have been emailing Ryan back and forth. I have an '08 LE5 and theyre saying that my harness should connect right to the 4 bar MAP... mine does not. It only plugs in to the factory 2 bar MAP. Plus, they also tuned for the 4 bar MAP sensor..... Will i be alright running the two bar map with a 4 bar tune? Do i have to cut and splice wires?? Any advice is much appreciated.
Old 02-20-2017, 04:56 PM
Dont run the wrong tune for you map because it will affect fueling if VE is left on and it will also impact if and when the car enters PE
Old 02-20-2017, 06:30 PM
Sooooo... what you think I should do then. Is it some cutting and splicing to get it to fit?
Old 02-20-2017, 06:35 PM
Im not sure, i have a 3 bar map from an LNF
Old 02-20-2017, 07:23 PM
Besides messing up logging and running rich, will this inherently ruin the vehicle if I drive it this way? Like significantly enough to where I shouldn't drive it??
Old 02-20-2017, 08:17 PM
You could leave it unplugged and not boost
Old 03-04-2017, 04:04 AM
Crav3's Avatar
​​​​​​​you connector should plug into the 4bar map. I have a 08 g5 gt with a 2.4 and the plug is the same as my 2.2 09 g5. I have a 4bar on the 09 g5 and it was hard to get it to plug in but with enough force it plugged in and works fine, reads just as well too.
Old 03-04-2017, 12:45 PM
chevygirl2006's Avatar
You can run your stock map if you wanted to. I did for a year then wired in the stock lsj map.
Cobalt_noob (03-04-2017)
Old 03-04-2017, 01:06 PM
^^this is also true. MAF only is what a lot of people do.
Old 03-04-2017, 09:11 PM
Right on, that is definitely good to know! It turns out I was the dummy, the 4 bar was plugged in the entire time. What threw me off was that they sent me the MAP for the LSJ and also the 4 bar... so there was the confusion.
All I'm waiting on now is for this weather to be consistent and I can rip the head off to check the damage on the pistons.... I dunno if I'm going to go through the trouble of replacing the engine, which ive already done once, I might as well go forged internals. I just wish you didn't need to sell an arm an a leg with a free kidney just to go forged. We will see. If pistons have just a little damage on them then I may just say screw it...
Old 03-05-2017, 12:39 AM
Crav3's Avatar
​​​​​​​your name makes sense now 😂 just kidding, good to know its working. I also had stock map until it broke 2 weeks ago and got the 4bar upgrade
Old 03-07-2017, 10:17 AM
Keepin' it real lol.
I heard running 2 bar would screw up logging though?? Is that true??
Quick Reply: 2.4 supercharged guys: few quick questions.
