2.4 w/oil cooler to 2.4 w/o oil cooler
The tstat housing is the same, it's not like lsj's from what I understand and from what I've seen on my motor which is an le5 with oil cooler out of an hhr.
It's set up like the lnf if I learned correctly. Basically there is a t fitting in the lower radiator hose and then a t fitting in the upper oil cooler hose.
The t fitting in the radiator goes to the lower oil cooler hose.
The t fitting in the upper oil cooler hose goes to the coolant reservior.
So I would be able to delete the oil cooler use the existing hoses (if long enough) and still use the t fitting for the reservoir? Or could I run the reservoir straight to the t stat housing in the oil cooled housing?
importkiller
09-30-2015 07:18 PM
