Clutch Help
Old 01-31-2016, 09:59 AM
Chaos_Six's Avatar
Clutch Help
I've supercharged my 2.4 with a 3.1 pulley on a KY Stage 2 clutch. It slipped.
My current build is the same car and everything but turbo swapped on an S256ET @ 28psi on a KY Stage 3. That slipped too.
Has anyone tried the ZZP 9.5" Clutch kit for the 2.2/2.4? What other clutch will hold because I'm sick of these clutches slipping. I refuse to buy another KY Clutch. Thanks!
Old 01-31-2016, 01:18 PM
Sl0wbaltSS's Avatar
Either 1 drive better, or 2, do clutch masters. it's on zzp's website. Clutch Masters Stage Clutches - Transmission & Drivetrain
Old 02-01-2016, 09:58 AM
Chaos_Six's Avatar
How do I know those will work with the F23 trans?
Old 02-01-2016, 11:27 AM
blueLNFftw's Avatar
Sounds like user or install error...
Old 02-02-2016, 09:20 AM
Chaos_Six's Avatar
No I've been talking to a few people and the mods I had on each clutch, I've surpassed the capacity for both which is why they end up slipping. I'm probably going to go KY Stage 4 with a lightweight flywheel now and hope it holds. F23 has a smaller surface area than the F35 which is why they don't hold like the F35 clutches do. That's why I was so interested in the ZZP 2.4L 9.5" Clutch kit but it seems like no one has used it..
Old 02-02-2016, 09:24 AM
blueLNFftw's Avatar
The Stage 3 is rated at almost 500ft/lbs of torque. Lot of guys are holding more than that on them as well.
Look at Clutchmasters or Southbend.
Old 02-02-2016, 07:05 PM
LsCobalt07's Avatar
I'd be careful with the lightweight flywheel. I feel like I've read somewhere on here that KY was designed to work best with a stock flywheel, but I'm not 100% sure.
Old 02-02-2016, 07:23 PM
blueLNFftw's Avatar
Most all clutches are designed to work best with OEM flywheels.
Lightweight flywheels can cause false Kr on LNF cars though.
LsCobalt07 (02-02-2016)
Old 02-09-2016, 11:32 AM
Chaos_Six's Avatar
I'll probably just run a KY Stage 4 and a lightweight flywheel. I'm going to use an LNF TOB though I think
Bandit2941
01-12-2017 08:06 AM
DC4LIFE
04-05-2016 12:30 AM
ThePanduuh
03-02-2016 09:10 AM
sS07NA
01-31-2016 10:03 AM
blueLNFftw
01-28-2016 09:04 AM
Quick Reply: Clutch Help
