Shifting into a brick wall
Old 07-21-2006, 10:29 AM
zomghax's Avatar
A couple of times now I've hit a "brick wall" when trying to shift (at high RPM's) from 1st to 2nd and less frequently, 2nd to 3rd. I only remember jamming the 2nd to 3rd shift once actually, but it was at the track and I blew a run as a result so it's a painful memory.
When this happens I never force it in, I back off, let the RPM's drop a bit and then gently slide it in. Kinda kills the momentum though, ya know?
Just wondering if there is a way to avoid this that does not include "not shifting at high RPM's". Will stiffening up the driveline with new mounts and/or inserts help? What about replacing the stock plastic shifter assembly with a short throw? Is it a problem with the tranny synchros? Anything else I can check?
How many other people run into this problem?
I'm thinking about a F35 swap next year so I'm not sure about the short throw. I don't want to buy one and then have to buy a different one in a year.
Old 07-21-2006, 10:34 AM
BLKSS's Avatar
It happens to everyone.
Old 07-21-2006, 10:46 AM
sscobalt06's Avatar
Same thing is happening to me i actually bent my linkage cables in the process. It sucks bad. Keeps getting worse.
Old 07-21-2006, 10:48 AM
06blackg85ss's Avatar
got my mounts and t.b. never had a problem
Old 07-21-2006, 02:08 PM
thatdaveguy's Avatar
There's a TSB on Pontiac Pursuits about this...I wonder if it's fixable.
RaginChopsuey
10-27-2015 01:27 PM
2009blackSS
09-30-2015 05:57 PM
DocSvensk
09-27-2015 02:24 PM
The Rookie24
09-20-2015 04:33 PM
roadrunner132
09-19-2015 04:35 PM
Quick Reply: Shifting into a brick wall
