ZZP Stage 2 Turbo Kit?
Old 10-03-2010, 06:49 PM
justypontiacg5gt's Avatar
Does anyone have some pictures of their stage 2 zzp turbo setup? I'd just like to see how everything is layed out. zzp only has one picture. im planning on doing this setup next month.
and does anyone have any comments on this kit? good or bad
Old 10-03-2010, 07:24 PM
DFZ24's Avatar
ill try to get some pic,
no bad comments as for now :P
Old 10-03-2010, 07:48 PM
mmcgee123's Avatar
heres right after we finished it looks a little diffrent now but u get the idea
Old 10-03-2010, 08:49 PM
DFZ24's Avatar
question: is yours (if it is that one yours) kit hit on the wall of the engine (passenger side) and the head of the engine????
the piece where intake is connected to, the one that comes from the ic.
Old 10-03-2010, 08:51 PM
mmcgee123's Avatar
It did slightly so I bent the bracket for the ic and messed around with the pipes
Old 10-03-2010, 08:57 PM
1 to 10 how hard is the build? what was the hardest part of the build?
Old 10-03-2010, 09:31 PM
ctg5040's Avatar
Here's mine, its not finished yet. I have a couple minor things to finish up and hopefully tuesday she'll be up and running.
Old 10-03-2010, 09:41 PM
mmcgee123's Avatar
Either the downpipe or getting the return oil bung welded up
Old 10-03-2010, 09:42 PM
mmcgee123's Avatar
Took like 6 hours and a case of beer
Old 10-03-2010, 09:44 PM
DFZ24's Avatar
yeah. also you can choose now.... before they didnt have it, a second bung on the dp for wideband.
also why i got a purple (i think or maybe is red) BOV lol i wanted something like silver (like ctg5040) :P
Old 10-03-2010, 09:52 PM
ctg5040's Avatar
For being hard, i honestly haven't had any past experience with turboing a car. My one buddy and I worked on it for a solid day and got a lot done. The rest I basically did on my own during nights and weekends i didn't have work or school. I'm not sayin anyone could do this but if you take your time and have common car knowledge i think you'll be alright. Also zzp always emailed me back asap when i had ?'s, and I sure had a bunch for this being my first build.
Old 10-03-2010, 10:20 PM
mmcgee123's Avatar
They welded up a second bung on my dp for free when I say welding up the bung I'm talking the bung for the drain oil line from the turbo bc u have to drop the Pan drill the whole so it drains above the windeg tray and find someone with a tig set up
Old 10-04-2010, 02:02 PM
could you thread it in to a bolt hole instead? or the drain hole?
Old 10-04-2010, 02:54 PM
mmcgee123's Avatar
I wouldn't
Old 10-04-2010, 03:10 PM
I wouldn't
it would be the same thing tho right?
Old 10-04-2010, 03:30 PM
mmcgee123's Avatar
If it's below the oil level it won't drain fast enough and back inthw turbo causing oil seals to blow out
Old 10-04-2010, 03:54 PM
would there be a bolt that is threaded into the block above the or close to?
Old 10-04-2010, 04:51 PM
mmcgee123's Avatar
That has oil pressure feed yes not for a drain and how r u gonna have a drain line that sits higher then turbo ?
Old 10-04-2010, 05:18 PM
im not saying higher than the turbo. im saying higher than the oil level in the bottom of the engine.
im just trying to find simpler ways to install the kit. not argue
Old 10-04-2010, 05:23 PM
anybody have pics of the turbo mounted? any pics of the kit layed out on the floor?
Old 10-04-2010, 06:34 PM
ctg5040's Avatar
I'll try to take some more pics of the kit on my car and post them later tonight.
Old 10-04-2010, 06:38 PM
thanks brosive
Old 10-04-2010, 06:40 PM
mmcgee123's Avatar
The Allen ports in the block are oil jackets that have pressured oil so no u can't have a drain line into a pressured oil port u would just have 2 pressure lines then so how bout u take ur oil pan off and take it to a machine shop that has a tig welder and a drill press and pay 30$ to have it done or u can do it the wrong way and mess up a $1000 turbo and possibly a engine just saying
Old 10-04-2010, 06:42 PM
just found out ZZP has an oil pan for 90 dollars and you get 45 back if you send you stocker back. good deal!!!
Cobalt & Ion ---> ZZ Performance
Old 10-04-2010, 06:44 PM
just a question. problem resolved with zzp
Quick Reply: ZZP Stage 2 Turbo Kit?
