Grinding in 3rd and 4th
Old 11-28-2016, 07:52 AM
CobiJack's Avatar
Since I bought the car I have had some minor grinding when shifting to 3&4. It's only a split second when I'm throwing it in place and only for the first few shifts, until the Trans warms up. This weekend I replaced my transmission fluid with redline mt-90, because I heard it was good for Grinding gears. Could this be something else? I already suspected that the flywheel has something wrong with it so I have plans on putting in a new clutch, flywheel and TOB. Will this solve it or should I just look for a new transmission?
Old 11-28-2016, 09:48 AM
FLASH1970's Avatar
Bad synchros in the trans.
Old 11-28-2016, 01:53 PM
CobiJack's Avatar
Good.
Old 11-28-2016, 03:51 PM
T-fog's Avatar
I agree with flash its typically the most common problem because of the NLS feature.
But I am curious if you have an aftermarket shifter or not? and if so is it aligned properly?
I had a similar issue on my old ss/sc with a hurst shifter when i first bought it and it just needed some minor adjustments. Here is the thread i found and used when i had my grinding issue. https://www.cobaltss.net/forums/08-1...inding-187224/
Old 11-28-2016, 06:36 PM
cluelessk's Avatar
It's mt 80 OE spec? Pretty sure it's recommended to use OEM fluid. Like ACDelco. Anything else causes problems.
Old 11-28-2016, 09:29 PM
LsCobalt07's Avatar
I thought MT-90 was for the F35. If it's an LE5 then it has an F23 transmission which uses GM#88861800.
Old 11-29-2016, 05:59 AM
CobiJack's Avatar
It was Grinding before the mt+90, so that is irrelevant. Stock shifter, haven't picked a short throw yet. I used the mt-90 because it is supposed to have better lubrication properties that reduce grinding.
Old 11-29-2016, 07:24 AM
CobiJack's Avatar
The grinding only lasts until the tranny has warmed up.
Old 11-29-2016, 09:05 AM
FLASH1970's Avatar
So, wait until the car warms up before driving. lol. I have the same problem with my eclipse grinding. If I take it easy it doesn't grind between shifts. Synchros going out are a common thing. Not sure how handy you are but if you have access to some tools like a press, a feeler gauges, torque wrench, sockets & ratchet... you could probably replace the synchros yourself. Or buy a used trans or have yours rebuilt.
Old 11-29-2016, 12:07 PM
CobiJack's Avatar
I would like to find a used Trans and rebuild the current one but I can't seem to find any rebuild kits for the F23.
