The Intake Thread
#151
ECU Retuning for Cold Air Intake Addition?
I'm looking to install the GM Performance Parts Cold Air Intake. I talked to my dealer and they said it won't require any retuning of the ECU, etc. I have a friend who got the stock CAI for his 08 Mustang V6 and he had to get a chip retuner so he could make the proper changes for the intake to work properly with the engine. Are there any chip issues involved with installing a CAI on a Cobalt? I've got a '08 Cobalt Sport w/ the 2.4L LE5. Thanks!
#152
#153
Sort of a similar question, but I have had my Injen CAI on for about 2 years and it just recently threw a CEL for the mass airflow sensor. So does that mean the car still thinks it has the regular intake on it and is delivering an improper fuel to air ratio? It does seem to run better when the CEL goes off (its intermittent). But, that could just be a placebo...
#154
**Wow I just realized how old this last post was. Whoops! I'd assume it's fixed by now.
#155
please give me suggestions
anyone have an ideas for me i have a 2006 2.4l sedan with carb(california) emissions i recently put a cold air intake on and it kept setting p0171 codes, i took it to the dealer and they told me i couldnt put a intake on a cali emission vehicle and once i put the original air ducting back on the light went out
#156
i was going to buy the injen special from the site here, with free shipping, but i found (what seems to be the same) intake for like, 50 bucks less, and with free shipping... the sellers ebay keep telling me the 2007 injen intake wont fit the 2008 2.4L..... this cant be true, i did enuf homework to know that it would fit.... can i get some back up?
#158
#160
I thinking of this eBay intake for $75 with free shipping. A intake is a intake as far as I'm concerned. Just different filters, and colors mostly, lol. As long as a k&n or aem filter fits the pipe it won't matter what it comes with in my opinion.
#161
Idle Air Control Valve?(2006 Model SS)
Hi, I am of course NEW to this thread and I am not even sure I am posting correctly...But anyway, here goes.....I have cleaned and replaced Plenty of IAC or Idle Air control valves in the past and I was looking for it on this car....I don't see one seperate like I have seen on other vehicles. So is it just built into the throttle body now?? the reason I was gonna clean it out was because of this little issue I have been having below:
When I press the clutch in between gears, (I go all the way to the floor), the RPM'S will raise a little before they drop down between gears... Also, when I rev the motor up while sitting in Nuetral the RPMs hang for a little while before they drop....The reason for this concern is cause I have a 2005 Sunfire with the 2.2L Ecotec with a 5-Speed and it doesnt do this. the RPMS drop instantly when the clutch is pressed and even if u slide it into Nuetral while going down the road, they dont hang like the cobalt and some times in the Cobalt if I rev the engine slightly while in nuetral going down the road, they will raise a little higher!! is this normal cause I have no idea!! i need to know if something is not functioning right or if I need to replace somethingThanks! in Advance!!.......Coop
#163
tryin to get some answers,have a 06 ss cobalt n/a with weapon r intake n as soon as i started th car th check engin light came on n th t/c light came on n th display n th car when i try to drive it tells me reduced engin power
#165
#166
K&N intake for sale! 2.4L https://www.cobaltss.net/forums/part...t-2-4l-309349/
#168
I just moved to Dallas and I just noticed that when sitting in traffic my air temperature goes up to about 160. Is that something I should be concerned about? I have a K&N short ram intake.
OrangeCoba
09-25-2015 06:06 PM
