OEM shift lights question
Old 09-10-2014, 09:11 PM
veilside's Avatar
Question OEM shift lights question
Hi!
I wanted to know which car or model the shift light in the speedo worked?
And I also wanted to know if it's possible to make it work...I have a 2006 2.4 and I never saw it working.
If it's possible, what do I have to do ?
Thanks for the answer!
Old 09-10-2014, 09:18 PM
Sl0wbaltSS's Avatar
OEM shift light? Only "OEM" Shift light is the RPD unit that has a build in thing like a shift light. I'm pretty sure it will work on any car by sending a signal at a certain rpm to the light to turn it on.
Old 09-10-2014, 09:28 PM
DFZ24's Avatar
You aee talking about the gear symbol with a + light?
Old 09-10-2014, 09:32 PM
veilside's Avatar
Yes, the + sign...the one in the speedo, at the right of the flashers light...can it be done to make it work?
I would like it to work just for the fun of it lol
Old 09-10-2014, 09:40 PM
DFZ24's Avatar
It works, just redline the car really high and it will come up.....
How i know, I accidentally went from 4th to 3rd couple times accelerating, and the light came up.
Old 09-10-2014, 10:15 PM
umrdyldo's Avatar
It worked on my manual LS in 2006. Was basically to help shift for mileage.
Totally wish someone would unlock it in a tune for use.
Old 09-11-2014, 03:48 PM
ss4me11's Avatar
I beleive in SS models it is used only for what it deams over revving, for base models its an economy shift light and super annoying. I've read that somewhere and owned 3 deltas that confirm it.
2008 G5 base- shift light worked for low rpm/eco
2005 Cobalt base - shift light worked for low rpm/eco
2010 SS/TC- Never seen it light up
Old 09-11-2014, 04:22 PM
veilside's Avatar
Ok, so no way to make it happen at a certai RPM with loke HPT?
Old 09-11-2014, 05:35 PM
umrdyldo's Avatar
I have not heard of it. At one point we discussed Trifecta trying to find it.
Not much has come of it.
It would be awesome as a shift light.
Old 09-11-2014, 05:48 PM
user 72239's Avatar
I would like it to as a shift light, or an actual MPG light...
not that I car about MPG now that im on the ZFR but still lol
Old 09-11-2014, 06:44 PM
DFZ24's Avatar
Interceptor is your best friend lol
Old 09-11-2014, 07:25 PM
Jesse's Avatar
I own HPTuners. I pulled 4 or 5 base tunes for 2.4 in 2006 and 2007 and found absolutely nothing related to shift light. It'd be nice though...
Old 09-11-2014, 08:09 PM
veilside's Avatar
Ok, thanks for the answer. I thought it could be made but I will forget the idea.
Old 09-11-2014, 08:30 PM
Verbatim's Avatar
Im 90% sure that you can turn it on in hpt
and you can adjust when it comes on
mine is a 06 le5 and it only comes on at 7200
Old 09-11-2014, 09:28 PM
jimbofug007's Avatar
im kinda confused then. im my old car the shift light would light up as it should but in my 08 sport cobalt i dont believe there is a shift light. tho i have never looked close enough to tell. my old car was an 08 cobalt ls. wonder if its a bulb thing or tuning thing
Old 09-11-2014, 09:55 PM
Verbatim's Avatar
the LED in the cluster should be there, cause they wouldnt use 2+ different clusters just with/without a shift light.
Its in the HPT tables
Old 09-12-2014, 09:36 PM
I looked today I see the light on my cobalt sport but it never lights up lol. Wonder what the deal is
Old 09-12-2014, 11:32 PM
DFZ24's Avatar
hit 7200+ rpm and you will see it light up lol
Old 09-12-2014, 11:35 PM
Lmao I red line at 6500 rpm.
Old 09-14-2014, 08:32 PM
Jesse's Avatar
I found a setting in my 2.2 auto tune I'm going to play with in HPT and see what happens.
Old 09-14-2014, 08:53 PM
YelloEye's Avatar
My 06 LT did, my 09 SS does not, even when over revved. I know because I accidentally went from 3rd to 2nd and tapped 7k for a split second. Thanks for the new head GM!
But back on topic. That "shift light" is going to be just as slow as the OEM gauges are since they're on the same low speed bus, and therefore not very useful as a shift light since it'll turn on way after you set it. The boost gauge is the easiest to notice since it's the quickest to change, but the speedo and tach are the same.
Old 09-14-2014, 10:39 PM
Jesse's Avatar
Results: changing the "lamp on" rpm changed nothing on the car, even after doing a write entire. Not sure about manual cars though.
Old 09-18-2014, 01:05 PM
So is it possible to have it working?
Old 09-18-2014, 01:51 PM
Jesse's Avatar
I'm going to say no. If there were a manual car nearby that wanted to let me screw around with the settings in their tune I would gladly do it and post results, but it does nothing on my auto even though the light is in my instrument cluster.
Old 09-18-2014, 02:22 PM
Administrator
Administrator
Staged07SS's Avatar
My shift light is the indicator for my race gas map.
Quick Reply: OEM shift lights question
