Piston Damage Opinion
So, my 'Balt has been down since about August. I got a supercharger in, new valves, new clutch and fidanza flywheel, headers with downpipe and ZZP tune (I know there is better but they have not done me wrong). Anyways, I just installed the supercharger after I replaced the valves. What happened is (trust me total screw up on my part, and partly because I was swapping cams from an old head that had less mileage cams [and I know you're not supposed to switch cams due to them mating to the specific head they came from]) but I need some solid opinion here. This is purely if you have had experience in this realm to give me an educated guess... I got the exhaust cam and intake cams mixed up. (Again, big screw up).
All of my intake valves bent... do you think the pistons are done or is there a slim chance they're ok??? This is before tax time comes around and I rip in to it and look. Guesses and opinions of the pistons are much appreciated
I am expecting the worse, and it is easy to do that. But, more or less seeing if anyone may shed some light on this... how tough are these pistons? has anyone experienced something similar and the pistons were fine? Thanks though nonetheless.
I would say plan on replacing the pistons and rods, and a light honing of the cylinders with a bead hone. That is assuming a part of a valve didn't break off and screw up the cylinder wall.
Just pulling the plug and shining a light down the plug hole you can sometimes see damage.
Find a junkyard 2.4 and just swap it in if money is of concern.
Cobalt_noob (02-18-2017)
excellent! See I read this somewhere too so that's what was giving me a thread of hope. Now what about the head joe, you think the valve guides would need to be replaced???
Nice! Well not your bent valves but that they were alright. How long did you drive that way? Because I must've drove roughly 120 miles like this. The crazy part is, I am estimating the valves bent pretty badly at around 80 miles, so we'll say 40 miles on bent valves..
So its funny you say this, i was literally just talking to my woman last night about my whole bent valve situation. Look you can believe this or not but im going to tell you, this is a freakin miracle...
I pretty much know, or at least have a close enough estimate to when the valves just got bent to hell. I drove my 'balt a total of 112 miles with the cams mixed up (meaning Intake cam on exhaust side and vice versa). It gave me hell the whole day and when i was heading back home from work on the interstate, it seemed like it was "acting" a bit better. So i started to test it by pushing my foot down slowly more and more and it was here when i know for a fact that my valves bent........... Here is the miracle......... i had to pull off to the hard shoulder , turn the key off and im sh**ting you not, she started back up and got me all the way home. When i got home, i turned her off.... let her cool down... and took off the valve cover, started investigating... sure enough, my springs on the left side are all stuck in the compressed state... so in other words, it had to have happened when i pulled off the shoulder... how i got home? well mr. , thats what happens when you crossover to, the Twilight Zone.
Oh and it didnt start when i checked it btw. The cams were just spinning and hitting none of the intake valves. So im just hoping that the pistons are still good, or with minor damage.
So im happy to say that the weather has cleared and ive finally got the head off my balt. Pistons are good!
So ive got ARP Head studs , ZZP #82 Springs, and whenever they get the LE5 Cams in, those will be on the way as well....
Does anyone have a preference on valves?
Engine Internals - Turbo Tech Racing
Not sure if theyre even worth it, but the Supertech ones or the Ferrea??
Valve Spring Compressor
Hey guys, anyone have a preference for a valve spring remover?!? Im using a Hawk one and im tellin ya what im having a hell of time with it! I mean, i can get the valve springs out with some effort but when i am installing the springs specifically im having one hell of a time!
Any recommends here guys????
Long story short, it can be done!
