removing plastic
removing plastic
is it safe for me to remove all the plastic in the engine compartment - i am only worried about the wires that are attached to the intake (is it safe to disconnect them)
are there any steps i should know about before removing the plastic
are there any plastic parts i SHOULDNT remove?
you shouldn't have to remove any wires to take the plastic off... take out the dipstick, (you don't have to but i broke mine taking the engine cover off) and take off the oil cap or it wont come off... there's only 2 rods holding it in, pull gently in the back left corner and the front right corner and it will snap right off... you may have to pull a little bit the first time... the black one in front of the engine cover to the left bottom side is your airbox, you can't take that off... it's not a cover... i wouldn't take off the fuse cover
the only "plastic" part you can take off is the big engine cover that says "Ecotec" on it... just unscrew your oil cap and pull... it sits on two rods and it'll come right off.
the front plastic piece is part of the stock air intake assembly... you'll have to get a aftermarket intake to get rid of that.
D4u - where do you live in NJ?
I live in bloomingdale... what about you?? here is a nice easy breakdown... sorry for the shitty quality i made it quickly in paint
ah yeah i already removed the main plastic part, i was just wondering about the intake area, thanks for the diagram....
i live in morristown and commute every day 80 -> 280 heading towards the oranges around 7 am and 5 pm in a black 2.4
XStylus
Forced Induction
09-16-2015 06:19 AM
chris88z24
09-08-2015 01:55 PM
Getaway_Driver
09-08-2015 09:41 AM
