ARK vs HAHN vs ZZP exhaust system???
truthfully its all in looks and sound. take a look at the thread in my sig for sound clips. If you are staying NA then the Hahn is to large anything over 2.5" is going to make you loss HP on a NA set up.
Either magnaflow (aka the exhaust ZZP sells) or any of the Ark exhausts are fine.
The Hahn will see a gain up in the high RPM's but you'll lose hp down low where you want it due to the fact that its a 3" diameter and considered to be to large for a N/A application on the 2.4L unless you are running a fully built motor.
